Use a portion of a part name in a drawing note.
I have a part name similar to this......12386-120 Motor Brace.  How do I create a note on the drawing, using the <FILENAME> parameter and only use the "12386-120"?  I only want to use the first 9 characters of a part/assembly name, regardless of the length of the filename.
damian.lewczyk
Autodesk Support
Autodesk Support
You can use this iLogic Rule:
oPartNum = iProperties.Value("Project", "Part Number")
oNewPartNum = Left(oPartNum, 9)
iProperties.Value("Custom", "FileNameFrist9characters") = oNewPartNum
MessageBox.Show(oNewPartNum,"You created new Custom Proerty")
Damian Lewczyk
Technical Support Specialist
