Upgrading Export DXF flat pattern from Assembly with iProperty naming
vkulikajevas
vkulikajevas
I need to Use this Rule (Or similar) to generate flat patterns from assembly sheet files. Problem is I can't figure it out how to make this rule to name all created DXF files to using every part info:
Description (From the sheet part) & " "  & Material (From the sheet part) & " " Stock Number (From the sheet part) " " QTY (From the assembly - i.d. QTY used in assembly of each part).
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
End If
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -'- - - - - - - - - - - - -Component - - - - - - - - - - - -'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models'this expects that the model has been saved
For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
Try
'Set the DXF target file name
Try
CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR")
Catch
CustomName ="XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert
End Try
oDataMedium.FileName = oFolder & "\" & CustomName  & " " & oFileName & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
End If
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR?OFILE"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
'just for check its works coretcly'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)'MessageBox.Show(i,"title",MessageBoxButtons.OK)'If i=2 Then'Exit Sub'End If
oCompDef.FlatPattern.ExitEdit
Catch
End Try
oDrawDoc.Close
Else
End If
Next
Replies (12)
JelteDeJong
The short answer:
long aswer i did have a look at your code. i implemented the properties en material in the filename of the dxf.
Also i found a a couple of things that could be done better. I added comments to the code and  changed it in a way i think is better.
        '--> first check if the is an assembly before you declare it to an AssemblyDocument
        If ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
            Exit Sub
        End If
        Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
        '--> oAsmDoc.DisplayName can show the extension depending on windows settings.
        '--> i guess that you try to remove the extensin here.
        '--> if you do it in this way your colega, with different windows settings, will have an unexpexted resilt.
        'Dim oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) - 4)
        Dim oAsmName = oAsmDoc.DisplayName.Replace(".iam", "")
        'get user input
        Dim RUsure = MessageBox.Show(
& vbLf & " " _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ", MessageBoxButtons.YesNo)
            Return
            ' Else <-- this is not needed.
        End If
        Dim oPath = ThisDoc.Path
        '--> it seems that you use oDataMedium only for the file path.
        '--> you might want to have a look at the k.i.s.s. design principl
        '--> https://en.wikipedia.org/wiki/KISS_principle
        '--> i think you wont need it.
        'Dim oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
        '--> oContext is declared her but is never used...
        'Dim oContext = ThisApplication.TransientObjects.CreateTranslationContext
        'oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        '--> oOptions is declared her but is never used...
        'Dim oOptions = ThisApplication.TransientObjects.CreateNameValueMap
        Dim oFolder = oPath & "\" & oAsmName & " DXF Files"
        End If
        Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
        For Each oRefDoc As Document In oRefDocs
            '--> this seem to replase the extension of the filename. Then you try to check with this
            '--> if it is saved (and probaly if its an part and not an assembly)
            '--> you can better use the Document.Dirty property. this will be false if the file is not saved.
            '--> also if the file exists but was not saved.
            '--> for checking if its a part we can use the Document.DocumentType.
            '--> last i did not see if you checked if it is realy a sheet metal part.
            '--> we can do that with the Document.SubType
            'Dim iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
            'If (System.IO.File.Exists(iptPathName)) Then
            '--> check if its a part:
            If (oRefDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then
                Continue For '--> this will make the program go to the next oRefDoc
            End If
'--> check if its a Sheetmetal part: If (oRefDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For '--> this will make the program go to the next oRefDoc End If
'--> check if its saved: If (oRefDoc.Dirty = True) Then '--> TODO ask the user if he/she wants to save? '--> oRefDoc.Save() Continue For '--> this will make the program go to the next oRefDoc End If
Dim oDrawDoc As PartDocument = ThisApplication.Documents.Open(oRefDoc.FullFileName, True) Dim oFileName = oRefDoc.DisplayName.Replace(".ipt", "") Dim oCompDef As SheetMetalComponentDefinition = oDrawDoc.ComponentDefinition Try 'Set the DXF target file name '--> you need to declare the CustomName before the try/cath or you will only be able to use its value in try/cath statement '--> i also declared the other values that you asked for. (with there default values so i dont have to do it in the cath block) Dim customPropertiesSet = oRefDoc.PropertySets.Item("Inventor User Defined Properties") Dim customName As String = "XXX" Try customName = customPropertiesSet.Item("PF_PRT_ZNR").Value Catch '--> TODO create a msgbox to want the user that the name can be starnge 'customName = "XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert End Try Dim designTrackingPropertiesSet = oRefDoc.PropertySets.Item("Design Tracking Properties") Dim description As String = designTrackingPropertiesSet.Item("Description").Value Dim StockNumber As String = designTrackingPropertiesSet.Item("Stock Number").Value Dim Material As String = oCompDef.ActiveSheetMetalStyle.Material.Name 'oDataMedium.FileName = oFolder & "\" & CustomName & " " & oFileName & ".dxf" Dim newFileName As String = oFolder & "\" & customName & " " & description & " " & StockNumber & " " & Material & ".dxf" If oCompDef.HasFlatPattern = False Then oCompDef.Unfold() Else oCompDef.FlatPattern.Edit() End If Dim sOut As String sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR?OFILE" oCompDef.DataIO.WriteDataToFile(sOut, newFileName) 'oCompDef.DataIO.WriteDataToFile(sOut, oDataMedium.FileName) oCompDef.FlatPattern.ExitEdit() Catch End Try oDrawDoc.Close() 'Else 'End If Next
Jelte de Jong
Blog: hjalte.nl - github.com
vkulikajevas
The code works really well! Thank you very much!
vkulikajevas
JelteDeJong, there is something wrong with the code when writing material to the parts.
It always writes AISI 304 instead of material that I applied to parts. Maybe you could have a fix for that? 🙂
JelteDeJong
My code does work but maby not as you expected probaly. It's a bit confusing but for sheetmetal parts the matrial that you can select in the top of your screen is an override from the material in the sheetmatal rules. I think it's best to use the sheetmatal rules to set the material because then it's possible to also set material thickness, k-factor's, and other stuff that is importend for sheetmetal parts in 1 click.
That being said if you want to use the override then change the code that get the material in this:
'Dim Material As String = oCompDef.ActiveSheetMetalStyle.Material.Name
Dim Material As String = oRefDoc.ActiveMaterial.DisplayName
Jelte de Jong
aurel_e
@JelteDeJong
Is there any way to run this ilogic rule "silently"? I mean without opening every sheet metal file. Actually it opens them save the flat pattern and close them. Can we change the code to make it run in background?
aurel_e
I think I figured it out
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True) -> False
aurel_e
Another question: is it possible to set the dxf layers? For instance: I would like to have the UNCONSUMED SKETCHES layer name Yellow, color Yellow.
JelteDeJong
hi it's possible you will need to change the option string (sOut). in your script replace the line:
with (see also comments in code):
Dim optionList As List(Of String) = New List(Of String)()
optionList.add("AcadVersion=2004") optionList.add("OuterProfileLayer=IV_OUTER_PR") optionList.add("UnconsumedSketchesLayerColor=255;0;0") 'here i make the UnconsumedSketchesLayer lines red! optionList.add("") 'you can add other options here optionList.add("") 'and more options ' if you want you can add more lines for more options
Dim sOut As String sOut = "FLAT PATTERN DXF?" For Each opt In optionList sOut = sOut & "&" & opt Next sOut = sOut & "?OFILE"
in the new code you can add option like they are discribed in the help files (search for: "Translate - Sheet Metal to DXF API Sample").
Jelte de Jong
aurel_e
@JelteDeJong  Thank you very much.
It works. This is the final part of my rule:
optionList.Add("AcadVersion=2004")
optionList.Add("OuterProfileLayer=0")
optionList.Add("InteriorProfilesLayer=0")
optionList.Add("UnconsumedSketchesLayer=YELLOW")
optionList.add("UnconsumedSketchesLayerColor=255;255;0") 'here i make the UnconsumedSketchesLayer lines red!
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2000" _
+ "&InvisibleLayers=IV_TANGENT;IV_FEATURE_PROFILES_D​OWN;IV_ARC_CENTERS;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_FEATURE_PROFILES;	IV_FEATURE_PROFILES_DOWN"
Next
Catch
End Try
oDrawDoc.Close
Else
End If
Next
aurel_e
@JelteDeJong
Something is not working properly:
I have an assembly with some Ipt that are derived parts. The code is exporting the derived part sources  as well.
Can we make the code to avoid it?
I would like the code to export just the components in this LOD, ignoring the suppressed parts as well.
Thank you.
I have assembly contain sub assembly, how can activate every part (as I assembly) inside this assembly or sub assembly and export dxf for each sheet metal parts
ricky_galetaSGGSQ
this code seems to be skipping a few parts and i have no idea why ?
