Updating user parameter with ilogic
ejaL9K8H
ejaL9K8H
Hi
I am trying to change the user parameter of an Asset model from an Assemply.
I would like my user paramter "ID_Number" to be equal to to the item number from the Bill of Materials.
I have used folowing code, but every time i run it, Inventor freezes and crashses...
What is the problem?
Thanks in advance
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
' Set the Row Merge Settings
oBOM.SetPartNumberMergeSettings(False)
Dim oBOMRow As BOMRow
For Each oBOMRow In oBOMView.BOMRows
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
    CompFileNameOnly = CompFullDocumentName.Substring(index + 1)
	ItemNumber = oBOMRow.ItemNumber
 	Parameter(CompFileNameOnly, "ID_Number") = ItemNumber
Next
Replies (21)
bradeneuropeArthur
Is the parameter
Always in the model available?
Otherwise you need to add that first!
Regards
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
ejaL9K8H
Yes the parameter is always available in the model.
I Added:
iLogicVb.UpdateWhenDone = True
The iproperties updates after the new parameter, but the paramter in factory properties remains the same..
bradeneuropeArthur
Dim oBOMRow As BOMRow = Nothing
Dim oDoc As Inventor.Document
	oDoc = oCompDef.Document
	'Doc.FullFileName
    Dim CompFullDocumentName As String = oDoc.FullFileName'oCompDef.Document.fullfilename
Next
Arthur Knoors
ejaL9K8H
The iProperties are updating, but I want my factory propererties to update as well.
The ID_Number is set to "X" as default.
Is it possible to synchronize these two values?
ejaL9K8H
This ilogic rule, is what updates the iproperties in the part/asset
iProperties.Value("Custom", "ID Number") = ID_Number
bradeneuropeArthur
What do you mean with Factory?
Arthur Knoors
ejaL9K8H
By Factory i mean the "Factory Properties" (at the left-hand-side) which follows the user parameters from the part/asset.
I am trying to biuld a Factory layout as an assembly which are buildup with Assets.
bradeneuropeArthur
For "Factory Design Suite"?
Arthur Knoors
ejaL9K8H
It is Assets properties which can be found in this menu:
ejaL9K8H
Nomally it updates with the assets user parameter:
bradeneuropeArthur
What Version of Inventor are you using?
And what vertical are you using, "Factory Design Suite"?
Arthur Knoors
ejaL9K8H
I am using AutodeskĀ® Factory Design Utilities, Version 2020.1.3
bradeneuropeArthur
I can't help you with that since I have not Inventor Factory Design installed!
Arthur Knoors
ejaL9K8H
I found a solution, but it is only working if i Run it as 2 separately codes:
Firstly the ID number is updated:
' Update ID Number
' Item Number = ID Number
	Try
	Catch
	End Try
Next
Secondly an Asset Tag is made, which updates the all asset models:
AddReference "Autodesk.Factory.PublicAPI.dll"
Imports Autodesk.Factory.PublicAPI.Currency.v2
Sub Main()
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Set up a variable for the component cccurrence
Dim oOcc As ComponentOccurrence, factoryInstance As IAssetInstance
'Access the Browser and Activate the "Bim Content" Browser Pane
Dim oBrowserPanes = ThisApplication.ActiveDocument.BrowserPanes
Dim Model_Browser_Pane As BrowserPane = oBrowserPanes.Item("Model")
Dim oOccNode As BrowserNode
For Each oOcc In oAsmCompDef.Occurrences
	 Try
 If (Not IsFactoryInstance(ThisApplication.ActiveDocument, oOcc, factoryInstance)) Then
  MessageBox.Show(oOcc.Name & " is NOT a Factory Asset", "Title")
 Else
  oOccNode = Model_Browser_Pane.TopNode.BrowserNodes.Item(oOcc.Name)
  oOccNode.DoSelect
  ChangeAssetTag(ThisApplication.ActiveDocument, oOcc, factoryInstance)
 End If
	Catch
  	End Try
Next
End Sub
'Use this Function To see If the models are Assets
Function IsFactoryInstance(layoutDoc As Document, oOcc As ComponentOccurrence, ByRef factoryInstance As IAssetInstance)
 Dim instances = Autodesk.Factory.PublicAPI.API.Instance.GetAssetInstances(layoutDoc)
 found = False
 For Each instance In instances
  If instance.NativeObject.Equals(oOcc) Then
   factoryInstance = instance
   found = True
   Exit For
  End If
 Next
 Return found
End Function
'The public subroutine will allow the editing of Asset Tags
Public Sub ChangeAssetTag(layoutDoc As Document, oOcc As ComponentOccurrence, Asset_Instance As IAssetInstance)
For Each grp In Asset_Instance.PropertyGroups
 If grp.Name = "AssetTag" Then
  For Each prop In grp.Properties
   If prop.Name = "Asset Tag" Then
	    New_Value = Parameter(oOcc.Name, "ID_Number") & " - " & iProperties.Value(oOcc.Name, "Project" ,"Part Number")
    	prop.Value = New_Value
   End If
  Next
 End If
Next
'After changed some value, you need To update the instance
Dim ins() As IAssetInstance={Asset_Instance}
Autodesk.Factory.PublicAPI.API.Instance.UpdateAssetInstances(layoutDoc,ins)
End Sub
Is it possible to merge these two codes and improve them?
I would like the code to save computer capacity and work faster.
Thanks in Advance
Ralf_Krieg
Hello
I don't have Factory Design Utilities installed, so I can't test it. Maybe it runs anyway.
Sub Main()
' Update ID Number
Dim oDoc = ThisDoc.Document
	Try
	Catch
	End Try
	If IsFactoryInstance(oDoc, oCompDef.Document, factoryInstance)) Then
		ChangeAssetTag(oDoc, oCompDef.Document, factoryInstance)
	End if
Next
End Sub
Function IsFactoryInstance(layoutDoc As Document, oDoc As Document, ByRef factoryInstance As IAssetInstance)
	 Dim found as Boolean=False
	  If instance.NativeObject.Definition.Document.Equals(oDoc) Then
	   found=true
	   Exit For
	  End If
	 Next
	 Return found
End Function
Public Sub ChangeAssetTag(layoutDoc As Document, oDoc As Document, Asset_Instance As IAssetInstance)
			New_Value = Parameter(oDoc.Name, "ID_Number") & " - " & iProperties.Value(oDoc.Name, "Project" ,"Part Number")
	   End If
	  Next
	 End If
Next
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
ejaL9K8H
This messages is showed:
Error in rule
The public member 'Name' of the type 'PartDocument' was not found.
WCrihfield
In this line:
Try replacing oDoc.Name with oDoc.DisplayName.
Wesley Crihfield
(Not an Autodesk Employee)
ejaL9K8H
Still getting an error message:
Error in rule:
Parameter: The component named "Test" was not found.
WCrihfield
Hmm.... Just 'shooting from the hip' here, but I'm thinking the problem may still be in that same line.  Sometimes using 'DisplayName' works OK, and sometimes it doesn't, depending on how you have things set-up.  Try using oDoc.FullDocumentName instead of oDoc.DisplayName.
Wesley Crihfield
