- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I could some assistance with the following code. The program updates all of the views on all sheets properly.
However, I would like the option to process the current sheet only.
Here is my current code.
Dim oDoc As DrawingDocument: oDoc = ThisDoc.Document oModel = ThisDoc.ModelDocument Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView oSheets = oDoc.Sheets If question1=vbNo Then For Each oSheet In oSheets oViews = oSheet.DrawingViews For Each oView In oViews 'make view label visible If oView.ViewType = 10501 Then oView.ShowLabel = True oView.Label.FormattedText = String1 & String2 & "<Br/>" & String4 &"<Br/>" & String3 End If Next Next Else oViews = oSheet.DrawingViews For Each oView In oViews If oView.ViewType = 10501 Then oView.ShowLabel = True oView.Label.FormattedText = String1 & String2 & "<Br/>" & String4 &"<Br/>" & String3 End If Next End If
