A few searches on this error does have some hits but none appear to match my conditions. I have a a part file I'm developing using ilogic/API and it works great except for an initial run of the iLogic code where it always fails with this unspecified error. After which it works great, I can't figure this one out and am reaching out for help. Including the part file and a video demonstrating my issue. I suspect you may have additional issues since part of this ilogic refers to some custom sheet metal rules that you likely do not have, REM out as needed. Inventor Pro 2021.1
Autodesk Inventor Certified Professional
