Announcements
Uncheck "Checked Date" with iLogic
rikard.nilsson
rikard.nilsson
Proir to 2018.3 we could use the following line.
iProperties.Value("Status", "Checked Date") = Nothing
But now that gives an error.
Does anyone know what to use now after 2018.3 if we want to Uncheck something with a Date in Iproperties
Regards
Rikard
Replies (11)
MechMachineMan
Well, you could always fire up the VBA and test the properties of a file that has the date unchecked.... just an idea.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
mr_ensing
I've got the exact same problem (but with VBA)!
Most of us run 2018.2, but one coworker is now running 2018.3.
2018.2, build 227, 10/24/2017
2018.3, build 284, 04/14/2018
The system with 2018.3 cannot change the "Checked Date" setting anymore. Finding it is no problem, reading it's value also great. But when VBA tries to uncheck (by way of date 1/1/1601) it faults.
I tried a kinds of variations of the code below, but no dice.
Private Sub TestDateChecked()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    oDoc.PropertySets.Item("Design Tracking Properties").Item("Date Checked").Value = "1601, 1, 1"
End Sub
mr_ensing
I can still change to a random date without problems. But unchecking the value results in an error.
Unchecking used to (and still does for 2018.2) work by changing the date to 1/1/1601.
If there is a new way, i would love to learn.
GeorgK
rikard.nilsson
Hi!
Thank you soo much for this!!
So adding the time was the difference from what i tested with..
Regards
Rikard
mr_ensing
Instant update:
The conclusion below is true for:  Build: 284, Release: 2018.3 - Date: Sat 04/14/2018
It fails on: Build: 284, Release: 2018.3.3 - Date: Thu 10/25/2018 (it sets the checked date to 1/1/1601)
/Instant update
For me (in VBA) this date/time works: "01-01-1601 01:00:00"
If i create a date and set it to #01-01-1601 01:00:00#, VBA auto-changes it to #1/1/1601 1:00:00 AM#, which works as well.
So below are the 2 ways:
    oDoc.PropertySets.Item("Design Tracking Properties").Item("Date Checked").Value = "01-01-1601 01:00:00"
Dim NullDate As Date NullDate = #1/1/1601 1:00:00 AM# oDoc.PropertySets.Item("Design Tracking Properties").Item("Date Checked").Value = NullDate End Sub
mr_ensing
A bit of experimenting later, and the situation seems to be as following:
For 2018.3: "01-01-1601 01:00:00"
For 2018.3.3: "01-01-1601 0:00:01"
No time to roll back at the moment. Production work first.
mr_ensing
So, i tested 3 versions of IV2018. Below are the date/time combinations that work to uncheck the Checked Date property.
Build: 227, Release: 2018.2 - Date: Tue 10/24/2017
- "01-01-1601"
- "01-01-1601 00:00:00"
- "01-01-1601 01:00:00"
- "01-01-1601 00:00:01"
The last thing i want, is to create different versions of my macro for the different builds of Inventor.
GeorgK
@Anonymous
This should be immediately fixed for all Inventor versions!
mr_ensing
I created a function to deal with these differences. It returns True/False to let the main sub know if it succeeded or not (and de main sub can log an error).
It's a terrible hack, but it's tested on 2018.2, 2018.3 and 2018.3.3. So i hope to be done with it.
VBA code:
Sub TestTheDamnThing()
    Dim pDoc As Document
    Set pDoc = ThisApplication.ActiveDocument
    If IsDateUnChecked(pDoc.PropertySets) Then
        MsgBox ("It works!")
    Else
        MsgBox ("It failed!")
End Sub
Function IsDateUnChecked(ByRef oPropSets As PropertySets) As Boolean
    Dim oCheckedDateProp As Property
    Set oCheckedDateProp = oPropSets.Item("Design Tracking Properties").Item("Date Checked")
    IsDateUnChecked = False
    Dim DatesArray(2) As String
    DatesArray(0) = "01-01-1601 00:00:00"   'works for 2018.2
    DatesArray(1) = "01-01-1601 01:00:00"   'works for 2018.3
    DatesArray(2) = "01-01-1601 00:00:01"   'works for 2018.3.3
    Dim i As Integer
    For i = LBound(DatesArray) To UBound(DatesArray)
        If oCheckedDateProp.Value = #1/1/1601# Then
            IsDateUnChecked = True
            Exit Function
        On Error Resume Next
            oCheckedDateProp.Value = DatesArray(i)
        On Error GoTo 0
    Next i
End Function
It seems that, if the right value is set, and the property is unchecked, it saves the value as: #1/1/1601#.
Only the date, no time. So i check against that value to see if i succeeded.
mr_ensing
A bit more testing and some minor changes:
    Dim DatesArray(2) As Date
    DatesArray(0) = #1/1/1601#              'works for 2018.2 AND 2018.3.3
    DatesArray(2) = "01-01-1601 00:00:01"   'works for 2018.3.3 (keep for backup)
    Dim i As Integer
            Exit Function
        On Error GoTo 0
    Next i
End Function
