Unable to suppress occurrence in subassembly
daniel.puchta
daniel.puchta
Hello everyone
I have this VBA code that check for each occurrence if it is suppressed. If yes it will unsuppress. Then it recursively calls itself if the occurrence is assembly.
Sub Main()
    Dim oAsmDoc As Inventor.AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = oAsmDoc.ComponentDefinition
    Dim oOccurrences As ComponentOccurrences
    Set oOccurrences = oAsmCompDef.Occurrences
    Zapnuti_occurrence oOccurrences, oAsmDoc
End Sub
Sub Zapnuti_occurrence(oOccurrences As ComponentOccurrences, oDoc As Inventor.AssemblyDocument)
    Dim oSuppress_Occurrence As Boolean
    Dim oModelState As ModelState
    Dim oModelState_created As Boolean
    oModelState_created = False
    For Each oOccurrence In oOccurrences 'tady to změnit na list
        oSuppress_Occurrence = False
        If oOccurrence.Suppressed = True Then
            If oModelState_created = False Then
                Set oModelState = ThisApplication.ActiveDocument.ComponentDefinition.ModelStates.Add("Part2Suppressed2")
            End If
            oOccurrence.Unsuppress
            oSuppress_Occurrence = True
        End If
        'do stuff...
        'If oSuppress_Occurrence = True Then
        '    oSuppress_Occurrence = False
        '    oOccurrence.Suppress
        'End If
        If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
            If InStr(oOccurrence.Definition.Document.DisplayName, new_element) = 0 Then
                oDoc.Update
            End If
            Set oDoc = ThisApplication.Documents.Open(oOccurrence.Definition.Document.FullFileName)
            Zapnuti_occurrence oOccurrence.SubOccurrences, oDoc
            oDoc.Save2
            oDoc.Close
        End If
    Next
End Sub
 When trying to unsuppress occurrence of subassembly, it throws this error:
 It does not matter if before trying to suppress occurrence It creates new model state or not. Please do you know how to solve this problem?
Replies (7)
CattabianiI
It's the desired behavior and pointed out in the LOD to MS migration document (https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/important-for-developers-working-with-l...
Suppress a ComponentOccurrenceProxy is not allowed.
To achieve what you want you should work in the context of oOccurrence parent document.
Or consider to make the occurrence invisible instead if it's just what you need.
Stakin
Sub Main()
'    Dim oAsmCompDef As AssemblyComponentDefinition
'    Set oAsmCompDef = oAsmDoc.ComponentDefinition
'    Dim oOccurrences As ComponentOccurrences
'    Set oOccurrences = oAsmCompDef.Occurrences
    Zapnuti_occurrence(oAsmDoc)
End Sub
Sub Zapnuti_occurrence(oDoc As Inventor.AssemblyDocument)
    oAsmCompDef = oDoc.ComponentDefinition
	Dim oOccurrence As ComponentOccurrence
'    Dim oSuppress_Occurrence As Boolean
'    Dim oModelState As ModelState
'    Dim oModelState_created As Boolean
'    oModelState_created = False
'            If oModelState_created = False Then
'                Set oModelState = ThisApplication.ActiveDocument.ComponentDefinition.ModelStates.Add("Part2Suppressed2")
'            End If
'            oSuppress_Occurrence = True
        End If
        'do stuff...
        'End If
			    Dim oSubAsmCompDoc As AssemblyDocument
    				oSubAsmCompDoc = oOccurrence.Definition.Document
'            If InStr(oOccurrence.Definition.Document.DisplayName, new_element) = 0 Then
'                oDoc.Update
'            End If
'            oDoc = ThisApplication.Documents.Open(oOccurrence.Definition.Document.FullFileName)
            Call Zapnuti_occurrence(oSubAsmCompDoc)
'            oDoc.Save2
'            oDoc.Close
        End If
    Next
End Sub
Which inventor version are you use?
In the 2021,there is no modelstate .
Try this
daniel.puchta
Thank you for your advice, could you be more specific what do you meant? Maybe post example of code?
I have modified the code that it is unsuppressing suboccurrences but this does not work (it throws error).
Heres the code:
Sub Main()
    Zapnuti_occurrence oAsmDoc
End Sub
    Set oAsmCompDef = oDoc.ComponentDefinition
    Dim oSubOccurrence As ComponentOccurrence
'            End If
        End If
        'do stuff...
        'End If
                Set oSubAsmCompDoc = oOccurrence.Definition.Document
'                oDoc.Update
'            End If
             For Each oSubOccurrence In oOccurrence.SubOccurrences
                 If oSubOccurrence.Suppressed = True Then
        '            End If
                    oSubOccurrence.Unsuppress
                End If
             Next
'            oDoc.Save2
'            oDoc.Close
        End If
    Next
End Sub
daniel.puchta
Sorry I work with Inventor 2022, so there are model states and the behaviour of occurrences and suboccurrences is different..
j.haggenjos
What if you change this:
To this:
Zapnuti_occurrence oDoc.ComponentDefinition.Occurrences, oDoc
daniel.puchta
Thank you, it works!
Here is the final code:
Sub Main()
End Sub
        End If
        'do stuff...
        'End If
                oDoc.Update
            End If
            oDoc.Save2
            oDoc.Close
        End If
    Next
End Sub
Stakin
Sub Main()
End Sub
Sub Zapnuti_occurrence( oDoc As Inventor.AssemblyDocument)
        oOccurrences =oDoc.ComponentDefinition.Occurrences
        End If
                oDoc.Update
            End If
            Rem In the Opened Asm File,All the oOccurrence were opened in memeroy,needn't use the document open method again; try this.
            Zapnuti_occurrence oOccurrence.Definition.Document
        End If
    Next
oDoc.Save
End Sub
