Unable to export the current BOM config
TONELLAL
TONELLAL
I need to export a BOM to Excel, using a BOM XML template, but without modifying the BOM current structure.
So I use :
  • save current BOM config in "BOM Tempo.xml"
  • load existing BOM config
  • load "BOM Tempo.xml"
The problem is the saved file "BOM Tempo.xml" does not match the current BOM config, it is always the same.
The code I use :
Sub test()
Set oAss = ThisApplication.ActiveDocument
Set oBOM = oAss.ComponentDefinition.BOM
'Define file name to export current BOM config
BOM_tempo = Environ("temp") & "\BOM_tempo.xml"
'if existing file, delete it
On Error Resume Next
Kill BOM_tempo
On Error GoTo 0
'Export active BOM config, in order to restore it
Call oBOM.ExportBOMCustomization(BOM_tempo)
'Load the custom BOM config file
oBOM.ImportBOMCustomization ("c:\temp\custom BOM.xml")
'...some code...
'Restore the original BOM config file
Call oBOM.ImportBOMCustomization(BOM_tempo)
End Sub
Normally I should have the same BOM config that I had at the beginning...
Replies (33)
bradeneuropeArthur
What version of inventor are you using?
Arthur Knoors
Autodesk Affiliations:
TONELLAL
2016 R3
bradeneuropeArthur
hi,
You are loading a different file:
Kill BOM_tempo
On Error GoTo 0
Arthur Knoors
TONELLAL
It is the right way :
  • Define the name for CURRENT config --> BOM_tempo.xml
  • Save current config in BOM_tempo.xml
  • Load CUSTOM config --> custom BOM.xml
  • ...some code...
  • Restore the ORIGINAL config --> BOM_tempo.xml
bradeneuropeArthur
BOM_tempo = "c:\temp\custom BOM.xml"
Kill BOM_tempo
On Error GoTo 0
Arthur Knoors
TONELLAL
  • Save original in TEMPO
  • Load CUSTOM
  • ...code...
  • Restore TEMPO
bradeneuropeArthur
The following:
Public Sub bomexp()
Dim a As Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
Dim c As BOM
Set c = b.ComponentDefinition.BOM
c.ExportBOMCustomization ("D:\BomTemporare.xml")
b.Save
c.ImportBOMCustomization ("D:\BomCustom.xml")
b.Save
c.ImportBOMCustomization ("D:\BomTemporare.xml")
b.Save
End Sub
EDIT.......................................................
Arthur Knoors
bradeneuropeArthur
The edit works for me....
The save was the issue!
Arthur Knoors
bradeneuropeArthur
Sub test()
Kill BOM_tempo
On Error GoTo 0
oAss.save
oAss.save
'...some code...
oAss.save
End Sub
This should work for your code......
Arthur Knoors
TONELLAL
Sorry that don't work...
The problem is really with the VBA command "ExportBOMCustomization".
If I stop the code just before the line "Call oBOM.ExportBOMCustomization(BOM_tempo)", export manually the BOM config from Inventor, don't execute the line and continue the macro it's ok.
bradeneuropeArthur
Try my code for example.
You forgot to declare the assembly doc as assemblydocument as the bom as bom....
Arthur Knoors
bradeneuropeArthur
That is the problem
Arthur Knoors
bradeneuropeArthur
This worked perfect by me at least.
Arthur Knoors
TONELLAL
No, doesn't function, with or without exact declaration.
bradeneuropeArthur
Try my code. Does this work. Be sure that the file is deleted manually when the code is running
Arthur Knoors
MechMachineMan
The exports worked just fine for me when I did a test run to get the desired results that you want (export with a new BOM Style, and revert the config back to the original).
This leaves me thinking you have 1 of 2 issues:
1. Your 'some code' is undoing part of the process or somehow causing issues.
2. Your code to overwrite the BOM_tempo is not working properly and instead of storing the BOM config from the current file, it's just using a config version that had been saved in the past, which is the config you are seeing it restored to (instead of it's original config).
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
TONELLAL
Here is the exact code I used to test :
Sub test()
Kill BOM_tempo
On Error GoTo 0
'1-Export active BOM config, in order to restore it
'2-Load the custom BOM config file
'3-Restore the original BOM config file
End Sub
 Test procedure :
  • Open an iam
  • From Inventor, edit BOM and modify columns
  • Close BOM
  • Launch the program in debug mode
  • STOP at 1
  • Check BOM_tempo value and check date of the file BOM_tempo.xml --> it's ok
  • Run and STOP at 2
  • EXIT the program, go back to Inventor
  • Open the BOM
  • Load manually the file BOM_tempo.xml --> NOT ok
TONELLAL
I found where is the bug:
  • From Inventor, the BOM has 3 tabs : Model, Structured and Parts only.
  • When you export manually, all the 3 tabs are exported
  • When you export by VBA, only the Model tab is exported, and it is only that tab which is restored, on Model, Structured and Parts only.
To check it :
1)VB export :
  • From Inventor, on an assembly, edit the BOM to have different configs on the 3 tabs
  • Using the macro, export the BOM config and stop the program
  • Manually, from Inventor, load the exported config :  you obtain same columns in all the 3 tabs
2)Manual export :
  • Manually, export the BOM config to BOM_tempo.xml
  • Manually, from Inventor, Edit and modify the BOM config
  • Manually, import the BOM config from BOM_tempo.xml : you obtain the right config you saved
chandra.shekar.g
Autodesk Support
Autodesk Support
@TONELLAL,
By default, Model tab is exported. If you want to export Structured tab, need to enable and export the same. Similarly for Parts Only tab. So, there are 3 xml files to export and import. Below VBA code exports different excels for different tabs.
Public Sub BOMExport()
    ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the BOM
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
    ' Set the structured view to 'all levels'
    oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    ' Set a reference to the "Structured" BOMView
    Dim oStructuredBOMView As BOMView
    Set oStructuredBOMView = oBOM.BOMViews.Item("Structured")
    ' Export the BOM view to an Excel file
    oStructuredBOMView.Export "C:\temp\BOM-StructuredAllLevels.xls", kMicrosoftExcelFormat
    ' Make sure that the parts only view is enabled.
    oBOM.PartsOnlyViewEnabled = True
    ' Set a reference to the "Parts Only" BOMView
    Dim oPartsOnlyBOMView As BOMView
    Set oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
    oPartsOnlyBOMView.Export "C:\temp\BOM-PartsOnly.xls", kMicrosoftExcelFormat
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
