Unable to change internal of documnet.
I am unable to use API PutInternalNameAndRevisionId to change document internal name and its revision id.
Below function takes 4 paramter.
void PutInternalNameAndRevisionId(string InternalNameToken, string RevisionIdToken, out string InternalName, out string RevisionId);
I don't understand what is mean by InternalNameToken and RevisionIdToken. I tried to use this API, however its throwing exception. Could you please help me with this?
I want to change the internal of documnet please suggest if you no any other way.
Thanks.
bradeneuropeArthur
This is a property that cannot be changed!
Arthur Knoors
Autodesk Affiliations:
Thanks for the help. Now its clear to me.
