TypeS of file Size
Maxim-CADman77
TypeS of file Size
Maxim-CADman77
I need to know how many different types of file size porerty are available through theAPI.
There are two ("Size" and "Size on disk") in UI (on general Tab of iProperty).
One of them is available with this iLogic code:
Dim myFile As New FileInfo(ThisDoc.PathAndFileName(True))
sizeInBytes = myFile.Length
But it returns error if executed on usaved file.
I wonder if it possible to get the size of RAM the usaved file consumes at the moment?
Please vote for Inventor-Idea Text Search within Option Names
bradeneuropeArthur
To my understanding, has an unsaved file no file-size.
It becomes a size at the moment the file is stored and written to the disk.
otherwise this is cache...
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
