Turntable View Rotation
I have created a turntable VBA macro that works in most cases but is a bit buggy depending on the initial view.
The rotation is about the Z axis and the issues occur when looking directly up or down the axis (Top or Bottom view)
The fault is the view jumps to a new position, the rotation starts doesn't compete 360 deg, then model disappears until clicking in the graphics window.
I could fix it by setting the view to home before rotating but would prefer to use any view if possible to make it more flexible.
Any suggestions how to improve it would be appreciated. :slightly_smiling_face:
Public Sub Turntable()
' Define Pi.
    Dim pi As Double
    pi = Math.Atn(1) * 4
'Rotation speed in Rad/Sec
    Dim rotSpeedRad As Double
    rotSpeedRad = 30 * pi / 180
'Define & check current document type
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    If oDoc.DocumentType = kDrawingDocumentObject Then GoTo Finished
'Get center point of the model
    Dim centerPoint As Point
    Dim minPoint As Point
    Set minPoint = oDoc.ComponentDefinition.RangeBox.minPoint
    Dim maxPoint As Point
    Set maxPoint = oDoc.ComponentDefinition.RangeBox.maxPoint
    Set centerPoint = ThisApplication.TransientGeometry.CreatePoint(    (minPoint.X + maxPoint.X) * 0.5, (minPoint.Y + maxPoint.Y) * 0.5, (minPoint.Z + maxPoint.Z) * 0.5)
'Camera and tuntable rotation
    Dim camera As Inventor.camera
    Set camera = ThisApplication.ActiveView.camera
    Dim totalRot As Double
    totalRot = 0
'Define rotation increment and axis
    Dim offsetRad As Double
    Dim rotAxis As Vector
    Set rotAxis = ThisApplication.TransientGeometry.CreateVector(0, 0, 1)
'Rotate view
    Dim upVector As UnitVector
    Set upVector = ThisApplication.TransientGeometry.CreateUnitVector(0, 0, 1)
    Do While (totalRot < 2 * pi)
    offsetRad = 0.05 * rotSpeedRad
    RotateCam camera, offsetRad, rotAxis, centerPoint, upVector
    totalRot = totalRot + offsetRad
    Loop
Finished:
End Sub
Public Sub RotateCam(camera As camera, ByVal offsetRad As Double,
rotAxis As Vector, centerPoint As Point, upVector As UnitVector)
Dim matrix As matrix
Set matrix = ThisApplication.TransientGeometry.CreateMatrix
Call matrix.SetToRotation(offsetRad, rotAxis, centerPoint)
Dim newEye As Point
Set newEye = camera.Eye
Call newEye.TransformBy(matrix)
camera.Eye = newEye
camera.upVector = upVector
Call camera.ApplyWithoutTransition
End Sub
It is based on code from here:
https://forums.autodesk.com/t5/inventor-customization/controlling-the-camera-using-ilogic/m-p/504033...
Replies (0)
