Turn off table title
S7RM7RPR
S7RM7RPR
Can anyone tell me how to turn off a custom table title? API help says to use the code below but I can't figure out how to bloody use it. Yes I'm frustrated lol. API help is a joke nothing works properly.
CustomTable.title() as boolean
rossano_praderi
Hi, which API help are you reading?
' CustomTable.ShowTitle() as boolean
' CustomTable.Title() as string CustomTable.ShowTitle = False ' turned off CustomTable.ShowTitle = True ' turned on
 Let me know is this work for you ( i didn't tested).
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
bretrick30
This will turn off the title for the first placed table on the Active Sheet.
SyntaxEditor Code Snippet
ThisDoc.Document.ActiveSheet.CustomTables.Item(1).Style.ShowTitle = False
rossano_praderi
This example will turn off the titles for all the custom tables on the ActiveSheet.
' First solution hide all customtable titles
' For Each ... Next
Dim cust As customtable
For Each cust In ThisDoc.Document.ActiveSheet.CustomTables
	'cust.Style.ShowTitle = False
	cust.ShowTitle = False
Next
MsgBox("")
' Second solution unhide all customtable titles
' FOR index TO value NEXT
For i=1 To ThisDoc.Document.ActiveSheet.CustomTables.count
	'ThisDoc.Document.ActiveSheet.CustomTables.Item(i).Style.ShowTitle = True
	ThisDoc.Document.ActiveSheet.CustomTables.Item(i).ShowTitle = True
Next
Bregs
Rossano Praderi
S7RM7RPR
Thank you for the suggestions. I actually have multiple tables but I only need to turn the title off for a specific table. This is what I've used.
I'm marking this as my solution to my particular problem but make sure to read the rest of the posts if you want to do it for multiple custom tables.
ThisDoc.Document.ActiveSheet.CustomTables.Item(4).ShowTitle = False
