turn off certain layers when exporting as dxf
mindaV3J2J
mindaV3J2J
I'm trying to export as dxf from parts; however, my script includes the tangent lines when exported, which means there are 3 bend lines instead of one. I want to turn off the IV_TANGENT and IV_ROLL_TANGENT layers.
My code is below.
Sub ExportFlatPatternToDXF2()
Dim SETFilePath As String
SETFilePath = "path"
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MsgBox "Please open an assembly document.", vbExclamation, "iLogic"
Exit Sub
End If
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator
Set oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
If oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim oSheetMetDoc As PartDocument
Set oSheetMetDoc = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
Dim oCompDef As SheetMetalComponentDefinition
Set oCompDef = oSheetMetDoc.ComponentDefinition
Dim oDef As FlatPattern
' If oCompDef.HasFlatPattern = False Then
' oCompDef.Unfold
' End If
Set oDef = oCompDef.FlatPattern
If oDef Is Nothing Then GoTo NextOcc
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2018&OuterProfileLayer=IV_INTERIOR_PROFILES"
Dim sFname As String
sFname = SETFilePath & "\" & oSheetMetDoc.DisplayName & ".dxf"
Dim oDataIO As DataIO
Set oDataIO = oCompDef.DataIO
oDataIO.WriteDataToFile sOut, sFname
oCompDef.FlatPattern.ExitEdit
End If
NextOcc:
Next oRefDoc
MsgBox "Flat patterns exported to " & SETFilePath, vbInformation, "iLogic"
End Sub
Replies (13)
johnsonshiue
Hi! Another way to do it without using an iLogic rule is to save the seeing as a configuration. Turn off the layers and save the configuration (at the top of the dialog). Keep using the same cfg file and those layers will be turned off.
Many thanks!
Software Test Engineer
mindaV3J2J
Hi!
Can you go into more detail? I'm a little lost with this response.
Curtis_Waguespack
Hi @mindaV3J2J
I think you just need to update your sOut line to something like this:
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2007" & _
"&OuterProfileLayer=IV_INTERIOR_PROFILES" &  _
"&InvisibleLayers = IV_TANGENT;IV_ROLL_TANGENT"
Reference link:
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=WriteFlatPatternAsDXF_Sample
related link:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/export-into-quot-dxf-quot-the-flat-p...
And here is an example of all options, just for reference:
Dim sOut As String
sOut="FLAT PATTERN DXF?AcadVersion=2007" &  _
"&TangentLayer=IV_TANGENT " &  _
"&BendLayer=IV_BEND" &  _
"&BendDownLayer=IV_BEND_DOWN" &  _
"&ToolCenterLayer=IV_TOOL_CENTER" &  _
"&ToolCenterDownLayer=IV_TOOL_CENTER_DOWN" &  _
"&ArcCentersLayer=IV_ARC_CENTERS" &  _
"&OuterProfileLayer=IV_OUTER_PROFILE" &  _
"&InteriorProfilesLayer=IV_INTERIOR_PROFILES" &  _
"&FeatureProfilesLayer=IV_FEATURE_PROFILES" &  _
"&FeatureProfilesDownLayer=IV_FEATURE_PROFILES_DOWN" &  _
"&AltRepFrontLayer=IV_ALTREP_FRONT" &  _
"&AltRepBackLayer=IV_ALTREP_BACK" &  _
"&UnconsumedSketchesLayer=IV_UNCONSUMED_SKETCHES" &  _
"&TangentRollLinesLayer=IV_ROLL_TANGENT" &  _
"&RollLinesLayer=IV_ROLL" &  _
"&InvisibleLayers=IV_TANGENT;IV_ROLL_TANGENT" &  _
"&TangentLayerColor=0;0;0 " &  _
"&endLayerColor=255;0;0" &  _
"&BendDownLayerColor=0;255;0" &  _
"&ToolCenterLayerColor=0;0;0" &  _
"&ToolCenterDownLayerColor=0;0;0" &  _
"&ArcCentersLayerColor=0;0;0" &  _
"&OuterProfileLayerColor=0;0;0" &  _
"&InteriorProfilesLayerColor=0;0;0" &  _
"&FeatureProfilesLayerColor=0;0;0" &  _
"&FeatureProfilesDownLayerColor=0;0;0" &  _
"&AltRepFrontLayerColor=0;0;0" &  _
"&AltRepBackLayerColor=0;0;0" &  _
"&UnconsumedSketchesLayerColor=-255;-255;-255" &  _
"&TangentRollLinesLayerColor=0;0;0" &  _
"&RollLinesLayerColor=0;0;0" &  _
"&MergeProfilesIntoPolyline=True"
I hope this helps.
Curtis
mindaV3J2J
Hi!
Thanks so much. However, when i run this, im getting an invalid procedure call or argument error, runtime error 5. Do you know why this is?
Thanks so much
mindaV3J2J
Actually, it outputted correctly i just changed the acad version to match mine; however, the tangent lines are still there. Any other ideas?
Curtis_Waguespack
Hi @mindaV3J2J
Ahh, I was just trying to match what you had in the original example as far as ACAD version, but goofed that up. You are correct there is no 2008 version ( I updated my examples).
I just did a quick test and see the same results as you. I'll see if I can figure out what the issue is. It's likely a syntax issue with the sOut line.
mindaV3J2J
Awesome i appreciate it. No rush whatsoever.
Curtis_Waguespack
@mindaV3J2J , I had extra spaces in the sOut line that was causing the issue. I'll update my previous posts so it doesn't trip someone else up in the future.
Try this:
Dim sOut As String
mindaV3J2J
worked!!! thanks so much
mindaV3J2J
Sorry last question and this is unrelated, is there a way i can get this to loop through multiple inventor assembly files and pirnt the dxfs of each assembly rather than just the one using VBA. I assume we will have to use visual basic for this.
Curtis_Waguespack
yeah, you can probably do this.
How are you identifying the assemblies?
Are they all in the same folder? All open in Inventor? Something else?
mindaV3J2J
yes they're all in the same folder. My coworker would like to be able to drop multiple assemblies in the same folder and output the respective flat parts in individual folders corresponding to the assembly it came from. thanks so much for your help as well
Curtis_Waguespack
@mindaV3J2J ,
This VBA example will open all the assemblies in a folder, and then close them. Add your DXF code where indicated.
Sub FindFilesWithComment()
    sName = ThisApplication.ActiveDocument.FullFileName
    Dim filesystem As Object
    Set filesystem = CreateObject("Scripting.FilesystemObject")
    Dim ActiveDoc As Document
    Set ActiveDoc = ThisApplication.ActiveDocument
    Dim FolderPath As String
    FolderPath = BrowseForFolder()
    If FolderPath = "" Then Exit Sub
    Dim oFSO As Object
    Dim oFolder As Object
    Dim oFile As Object
    Dim oFiles As Object
    Dim oFileNames As String
    oFileNames = "Files with comments: " & oComment
    Set oFSO = CreateObject("Scripting.FileSystemObject")
    Set oFolder = oFSO.GetFolder(FolderPath)
    For Each oFile In oFolder.Files
        If LCase(oFSO.GetExtensionName(oFile.Name)) = "iam" Then
            sFilename = FolderPath & "\" & oFile.Name
            'set option to false to open invisible and run faster
            Set oAsmDoc = ThisApplication.Documents.Open(sFilename, True)
            MsgBox (oAsmDoc.FullFileName)
                'put your DXF code here
            Next oRefDoc
            If Not ActiveDoc Is oAsmDoc Then oAsmDoc.Close (True) 'true = skip save
        End If
    Next oFile
End Sub
Function BrowseForFolder(Optional OpenAt As Variant) As Variant
    Dim ShellApp As Object
    Set ShellApp = CreateObject("Shell.Application"). _
    BrowseForFolder(0, "Please choose a folder", 0, OpenAt)
    On Error Resume Next
    BrowseForFolder = ShellApp.self.Path
    On Error GoTo 0
    Set ShellApp = Nothing
    Select Case Mid(BrowseForFolder, 2, 1)
    Case Is = ":"
        If Left(BrowseForFolder, 1) = ":" Then GoTo Invalid
    Case Is = "\"
        If Not Left(BrowseForFolder, 1) = "\" Then GoTo Invalid
    Case Else
        GoTo Invalid
    End Select
    Exit Function
Invalid:
    BrowseForFolder = ""
End Function
