Trying to add icon to button in Inventor plugin
saikiran.nT432F
saikiran.nT432F
Iam trying to add an icon in Inventor plugin button but for the following code added icon is not displaying or getting the error saying "Parameter is incorrect" or if i change the line
Dim largeIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.Arturo_Wibawa_Akar_Icon) to
Dim largeIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp("D:\Desktop\Videos\Arturo-Wibawa-Akar-Icon.ico")
iam using icon with size 96X96 and tried wityh sizes 32X36. 16X16.
Any help in resloving in this issue is much appreciataed. Thanks in advance.
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
' Initialize AddIn members.
g_inventorApplication = addInSiteObject.Application
' Connect to the user-interface events to handle a ribbon reset.
m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
' TODO: Add button definitions.
'Sample to illustrate creating a button definition.
Dim largeIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.YourBigImage)
Dim smallIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.YourSmallImage)
Dim controlDefs As Inventor.ControlDefinitions = g_inventorApplication.CommandManager.ControlDefinitions
m_sampleButton = controlDefs.AddButtonDefinition("sampledef", "Toapp", CommandTypesEnum.kShapeEditCmdType, AddInClientID)
m_sampleButton.LargeIcon = largeIcon
m_sampleButton.SmallIcon = smallIcon
' Add to the user interface, if it's the first time.
If firstTime Then
AddToUserInterface()
End If
End Sub
Public NotInheritable Class PictureDispConverter
<DllImport("OleAut32.dll", EntryPoint:="OleCreatePictureIndirect", ExactSpelling:=True, PreserveSig:=False)> _
Private Shared Function OleCreatePictureIndirect( _
<MarshalAs(UnmanagedType.AsAny)> ByVal picdesc As Object, _
ByRef iid As Guid, _
<MarshalAs(UnmanagedType.Bool)> ByVal fOwn As Boolean) As stdole.IPictureDisp
End Function
Shared iPictureDispGuid As Guid = GetType(stdole.IPictureDisp).GUID
Private NotInheritable Class PICTDESC
Private Sub New()
End Sub
'Picture Types
Public Const PICTYPE_BITMAP As Short = 1
Public Const PICTYPE_ICON As Short = 3
<StructLayout(LayoutKind.Sequential)> _
Public Class Icon
Friend cbSizeOfStruct As Integer = Marshal.SizeOf(GetType(PICTDESC.Icon))
Friend picType As Integer = PICTDESC.PICTYPE_ICON
Friend hicon As IntPtr = IntPtr.Zero
Friend unused1 As Integer
Friend unused2 As Integer
Friend Sub New(ByVal icon As System.Drawing.Icon)
Me.hicon = icon.ToBitmap().GetHicon()
End Sub
End Class
Public Class Bitmap
Friend cbSizeOfStruct As Integer = Marshal.SizeOf(GetType(PICTDESC.Bitmap))
Friend picType As Integer = PICTDESC.PICTYPE_BITMAP
Friend hbitmap As IntPtr = IntPtr.Zero
Friend hpal As IntPtr = IntPtr.Zero
Friend unused As Integer
Friend Sub New(ByVal bitmap As System.Drawing.Bitmap)
Me.hbitmap = bitmap.GetHbitmap()
End Sub
End Class
End Class
Public Shared Function ToIPictureDisp(ByVal icon As System.Drawing.Icon) As stdole.IPictureDisp
Dim pictIcon As New PICTDESC.Icon(icon)
Return OleCreatePictureIndirect(pictIcon, iPictureDispGuid, True)
End Function
Public Shared Function ToIPictureDisp(ByVal bmp As System.Drawing.Bitmap) As stdole.IPictureDisp
Dim pictBmp As New PICTDESC.Bitmap(bmp)
Return OleCreatePictureIndirect(pictBmp, iPictureDispGuid, True)
End Function
End Class
bradeneuropeArthur
use this way:
m_sampleButton = controlDefs.AddButtonDefinition("sampledef", "Toapp", CommandTypesEnum.kShapeEditCmdType, AddInClientID,"","",smallIcon,largeIcon,ButtonDisplayEnum.kDisplayTextInLearningMode)
Arthur Knoors
Autodesk Affiliations:
JelteDeJong
I wrote a blog post/tutorial about addin icons to your buttons. You might find it interesting.
http://www.hjalte.nl/tutorials/61-adding-icons-to-your-buttons
some important points:
A “standard” size icon is 16 pixels wide and 16 pixels high. A large size icon is 32 wide by 32 high. Inventor is very strict about this. if you get it wrong then it won't work.
the method PictureDispConverter.ToIPictureDisp(...) will only accept objects of the type "System.Drawing.Icon" or "System.Drawing.Bitmap". Therefore this won't work:
Jelte de Jong
Blog: hjalte.nl - github.com
saikiran.nT432F
Thank you so much for your quick relpy @JelteDeJong.
With the Blog you shared i was able to add standard icon, but whatever i do i am not able to make it work for large icon. In the screen shot shared below i want to create an icon like "Team Web" but what i created is "Display name".
I followed the 16X16 for Standard and 32X32 for Large Icon. I shared the Code i am using and the .png testing files as well.
Please go through them any suggestions will be a lot of help. Thanks in advance
saikiran.nT432F
Hello Everyone,
About the Issue (Trying to add icon to button in Inventor plugin), i tried all the available methods i could find on the Forums and other online sites with different file sizes. But iam unable to make it work for Large Icon (32X32).
If any one have an idea as how to resolve this please guide me. Thanks in advance.
