Trouble Porting Addin to .NET8
tdant
tdant
A couple of days ago I successfully followed this guide to port an old addin for use in Inventor 2025 with no trouble. Today I'm doing the same thing for a different addin, and got stuck at step 11. After changing the post-build event text in the vbproj file, I'm getting this error. Any ideas?
bradeneuropeArthur
Could you send me the project files. Can also via email!
Arthur Knoors
Autodesk Affiliations:
