Announcements
Transfering iProperties from drawing into model
Mark
Mark
Can any one help?
I'm trying to establish if there is a way to transferring the standard iProperty information from 'Revision Number' within the 2D Inventor drawing, back into the associated 3D model. I know it is possible the other way, so I would have thought there must be a way to transfer the data from the drawing back to the model.
Any help or suggestions would be helpful.
Mark
Replies (8)
Owner2229
Hey, it would be something like this:
This will do it for the first referenced document:
Dim oDoc As Document = ThisApplication.ActiveDocument
If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
Dim oPropSet As PropertySet = oDoc.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}") 'Project Dim RN As String = oPropSet.Item("Revision Number").Expression
Dim ModelDoc As Document = oDoc.ReferencedDocuments(1) Dim oPropSetA As PropertySet = ModelDoc.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}") 'Project oPropSetA.Item("Revision Number").Expression = RN
ModelDoc.Save() 'Optional save
And this'll do it for all referenced documents:
For Each ModelDoc As Document In oDoc.ReferencedDocuments Dim oPropSetA As PropertySet = ModelDoc.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}") 'Project oPropSetA.Item("Revision Number").Expression = RN
Next
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Mark
Mike
Thanks for the quick reply, however when I tried running both of the codes I get the following error message
Error in rule: Data Transfer, in document: Test.idw
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
As I'm no expert in I-Logic, it might be that I've made a simple error, so could you advise what could cause such an error message.
Cheers
Mark
Owner2229
It should be "Standard Revision" instead of "Revision Number". And the value can't be empty:
Dim oPropSet As PropertySet = oDoc.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}") 'Project Dim RN As String = oPropSet.Item("Standard Revision").Expression
If RN = "" Then Exit Sub
Next
Mike
Mark
Mike I've tried running both of these new codes. Both run without any errors, but as you'll see from the attached the 'Revision Number' in the model has remained at '1' even after the updating the drawing to revision '2' and running both codes. Have you any other suggestions, or am I missing a simple step. Cheers Mark
Jesper_S
Hi.
I use this code to get iProperties from the model to the drawing.
SyntaxEditor Code Snippet
If (ThisDrawing.ModelDocument Is Nothing) Then Return
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
'read the values from the Custom iProperties in the part file
'and apply them to the Custom iProperties with the same name in the drawing
iProperties.Value("Project", "Part Number")=iProperties.Value(modelName, "Project", "Part Number")
iProperties.Value("Summary", "Company")=iProperties.Value(modelName, "Summary", "Company")
iProperties.Value("Project", "Project")=iProperties.Value(modelName, "Project", "Project")
iProperties.Value("Summary", "Title")=iProperties.Value(modelName, "Summary", "Title")
Then i use this to send back iProperties to the model from the drawing.
' Set a reference to the drawing document.' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'Get the name Of the first model in the drawing
iProperties.Value(modelName, "Project", "Part Number")=iProperties.Value("Project", "Part Number")
iProperties.Value(modelName, "Summary", "Company")=iProperties.Value("Summary", "Company")
iProperties.Value(modelName, "Project", "Project")=iProperties.Value("Project", "Project")
iProperties.Value(modelName, "Summary", "Title")=iProperties.Value("Summary", "Title")
iLogicVb.UpdateWhenDone = True
//Jesper
Mark
The code works perfectly, and is easy to add extras to.
Many thanks
Smiley Happy
Mark
Owner2229
Hey, apparently on the "Project" tab is a different type of revision (internal), so the "Revision Number" was correct, but the Property Set wasn't, try it now:
For first referenced document:
Dim oPropSet As PropertySet = oDoc.PropertySets.Item("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}") Dim RN As String = oPropSet.Item("Revision Number").Expression
Dim ModelDoc As Document = oDoc.ReferencedDocuments(1) Dim oPropSetA As PropertySet = ModelDoc.PropertySets.Item("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}")
For all referenced documents:
For Each ModelDoc As Document In oDoc.ReferencedDocuments Dim oPropSetA As PropertySet = ModelDoc.PropertySets.Item("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}") oPropSetA.Item("Revision Number").Expression = RN
Next
Mike
Jesper_S
Yes, it's a quite easy code.
I have them like a button in a form in my drawing for when I fill in all the properties
for the drawing.
Please mark this as Accepted Solution.
//Jesper
