transaction manager help
I am using code to check hole size and alignment of assembly. the only problem is when I click to undo I have to click it more times than I actually can. I have been trying to set up a transaction within the code so it groups the rule altogether this is my code is there any way to do this since  sub commands
 Sub main
	 End Sub
 Sub face()
        Dim m_Inventor As Inventor.Application
        m_Inventor = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Dim oDoc As AssemblyDocument
        oDoc = m_Inventor.ActiveDocument
        Dim oCompdef As AssemblyComponentDefinition
        oCompdef = oDoc.ComponentDefinition
        Dim oBody1 As SurfaceBody
        Dim oBody2 As SurfaceBody
        oBody1 = m_Inventor.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select first body")
        oBody2 = m_Inventor.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select a body to compare")
        Dim oFace As Face
        Dim oAxis As WorkAxis
        For Each oFace In oBody1.Faces
            If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
                oAxis = oCompdef.WorkAxes.AddFixed(oFace.Geometry.BasePoint, oFace.Geometry.AxisVector)
                Dim comparedFace As Face
                comparedFace = CompareFaces(oAxis, oBody2, oCompdef)
                If comparedFace Is Nothing Then
                    oAxis.Name = oAxis.Name & "_misaligned"
                Else
                    Dim oHoleFeature1 As HoleFeature
                    oHoleFeature1 = oFace.CreatedByFeature
                    Dim dia1 As Double
                    dia1 = oHoleFeature1.HoleDiameter.Value
                    dia1 = dia1 * 10 'Converting cm to mm
                    Dim oHoleFeature2 As HoleFeature
                    oHoleFeature2 = comparedFace.CreatedByFeature
                    Dim dia2 As Double
                    dia2 = oHoleFeature2.HoleDiameter.Value
                    dia2 = dia2 * 10 'Converting cm to mm
                    If Math.Round(dia1, 4) = Math.Round(dia2, 4) Then
                        messagebox.show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => OK - Default")
                    ElseIf Math.Round(dia1, 4) >= Math.Round(dia2, 4) And Math.Round(dia1, 4) <= Math.Round(dia2, 4) + 0.5 Then
                        messagebox.Show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => OK - Special Type")
                    Else
                        messagebox.Show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => Not OK")
                    End If
                End If
            End If
        Next
        Dim oPane As BrowserPane
        oPane = oDoc.BrowserPanes.ActivePane
        Dim alignedNodes As ObjectCollection
        alignedNodes = m_Inventor.TransientObjects.CreateObjectCollection
        Dim misAlignedNodes As ObjectCollection
        misAlignedNodes = m_Inventor.TransientObjects.CreateObjectCollection
        For i = 4 To oCompdef.WorkAxes.Count
            oAxis = oCompdef.WorkAxes.Item(i)
            Dim misaligned As Boolean
            misaligned = EndsWith(oAxis.Name, "misaligned")
            Dim oNode As BrowserNode
            If misaligned = True Then
                oNode = oPane.GetBrowserNodeFromObject(oAxis)
                misAlignedNodes.Add(oNode)
            Else
                alignedNodes.Add(oNode)
            End If
        Next
        Dim alignedAxes As BrowserFolder
        alignedAxes = oPane.AddBrowserFolder("Aligned Axes", alignedNodes)
        Dim misAlignedAxes As BrowserFolder
        misAlignedAxes = oPane.AddBrowserFolder("MisAligned Axes", misAlignedNodes)
    End Sub
    Public Function CompareFaces(ByVal oAxis1 As WorkAxis, ByVal oBody As SurfaceBody, ByVal compDef As AssemblyComponentDefinition) As Face
        For Each oFace As Face In oBody.Faces
                oAxis = compDef.WorkAxes.AddFixed(oFace.Geometry.BasePoint, oFace.Geometry.AxisVector)
                If oAxis.Line.IsColinearTo(oAxis1.Line) Then
                    oAxis.Delete()
                    Return oFace
                    Exit Function
                Else
                    oAxis.Delete()
                End If
            End If
        Next
        Return Nothing
    End Function
    Public Function EndsWith(Str As String, ending As String) As Boolean
        Dim endingLen As Integer
        endingLen = Len(ending)
        EndsWith = (Microsoft.VisualBasic.Right(Trim(UCase(Str)), endingLen) = UCase(ending))
    End Function
Replies (8)
AlexFielder
Hi again @Anonymous
Here is the simplest example of a transaction I can provide:
Option Explicit On
Public Sub Main()
    If TypeOf ThisApplication.ActiveDocument Is PartDocument Then
        Dim pyramidheight As String = InputBox("How high?", "Pyramid height", "10")
        GeneratePyramid(pyramidheight)
    Else
        MessageBox.Show("Suggest you create a new part file and run this rule again!")
    End If
End Sub
Public Sub GeneratePyramid(ByVal pyramidHeight As String)
    Dim height As Integer = Convert.ToInt32(pyramidheight)
    Dim rowCount As Integer = 1
    Dim spacing As Double = 10 'units = cm
    Dim oPartDocument As PartDocument = ThisApplication.ActiveDocument
    Dim oCompDef As PartComponentDefinition = oPartDocument.ComponentDefinition
    Dim oTrans As TransientGeometry = ThisApplication.TransientGeometry
    Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oPartDocument, "Create pyramid of points")
    'i = row
    'j = column
    Dim XSpacing As Double = 0
    Dim YSpacing As Double = 0
    Dim ZSpacing As Double = 0
    For i As Integer = height To 0 Step -1
        'Dim tmpPoint As Point = ThisApplication.TransientGeometry.CreatePoint(0, 0, 0)
        For j As Integer = 1 To i
            Dim wp As WorkPoint = oCompDef.WorkPoints.AddFixed(oTrans.CreatePoint(XSpacing, YSpacing, ZSpacing))
			wp.Name = "WP" & i.ToString() & "." & j.ToString()
            'set up X Spacing
            XSpacing += spacing
        Next
        'For j As Integer = 1 To rowCount
        YSpacing += spacing
        XSpacing = (spacing * rowCount) / 2
        'Next
        rowCount += 1
    Next
    trans.End()
End Sub
Sub updatestatusbar(ByVal message As String)
    ThisApplication.statusbartext = message
End Sub
Sub updatestatusbar(ByVal percent As Double, ByVal message As String)
    ThisApplication.statusbartext = message + " (" & percent.ToString("P1") + ")"
End Sub
This process is explained in more detail on the following page:
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-991ABB26-6113-4E27-83F8-1699F259772E
:slightly_smiling_face:
Thank you again for all the help. The reason I posted I keep getting an error every time I try to place a transaction here is the error I keep receiving. I didn't know if i needed to place a transaction in each sub step of code
AlexFielder
Post the code you have and I'll take a look.
ok here we go
Sub Main() Dim m_Inventor As Inventor.Application m_Inventor = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") Dim oDoc As AssemblyDocument oDoc = m_Inventor.ActiveDocument Dim oCompdef As AssemblyComponentDefinition oCompdef = oDoc.ComponentDefinition Dim oBody1 As SurfaceBody Dim oBody2 As SurfaceBody oBody1 = m_Inventor.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select first body") oBody2 = m_Inventor.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select a body to compare") Dim oFace As Face Dim oAxis As WorkAxis Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oPartDocument, "Hole Alignment") For Each oFace In oBody1.Faces If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then oAxis = oCompdef.WorkAxes.AddFixed(oFace.Geometry.BasePoint, oFace.Geometry.AxisVector) Dim comparedFace As Face comparedFace = CompareFaces(oAxis, oBody2, oCompdef) If comparedFace Is Nothing Then oAxis.Name = oAxis.Name & "_misaligned" Else Dim oHoleFeature1 As HoleFeature oHoleFeature1 = oFace.CreatedByFeature Dim dia1 As Double dia1 = oHoleFeature1.HoleDiameter.Value dia1 = dia1 * 10 'Converting cm to mm Dim oHoleFeature2 As HoleFeature oHoleFeature2 = comparedFace.CreatedByFeature Dim dia2 As Double dia2 = oHoleFeature2.HoleDiameter.Value dia2 = dia2 * 10 'Converting cm to mm If Math.Round(dia1, 4) = Math.Round(dia2, 4) Then messagebox.Show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => OK - Default") ElseIf Math.Round(dia1, 4) >= Math.Round(dia2, 4) And Math.Round(dia1, 4) <= Math.Round(dia2, 4) + 0.5 Then messagebox.Show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => OK - Special Type") Else messagebox.Show("Hole diameter of plate 1 = " & dia1 & " compared with Hole diameter of plate 2 = " & dia2 & " => Not OK") End If End If End If Next Dim oPane As BrowserPane oPane = oDoc.BrowserPanes.ActivePane Dim alignedNodes As ObjectCollection alignedNodes = m_Inventor.TransientObjects.CreateObjectCollection Dim misAlignedNodes As ObjectCollection misAlignedNodes = m_Inventor.TransientObjects.CreateObjectCollection For i = 4 To oCompdef.WorkAxes.Count oAxis = oCompdef.WorkAxes.Item(i) Dim misaligned As Boolean misaligned = EndsWith(oAxis.Name, "misaligned") Dim oNode As BrowserNode If misaligned = True Then oNode = oPane.GetBrowserNodeFromObject(oAxis) misAlignedNodes.Add(oNode) Else oNode = oPane.GetBrowserNodeFromObject(oAxis) alignedNodes.Add(oNode) End If Next Dim alignedAxes As BrowserFolder alignedAxes = oPane.AddBrowserFolder("Aligned Axes", alignedNodes) Dim misAlignedAxes As BrowserFolder misAlignedAxes = oPane.AddBrowserFolder("MisAligned Axes", misAlignedNodes) trans.end End Sub Public Function CompareFaces(ByVal oAxis1 As WorkAxis, ByVal oBody As SurfaceBody, ByVal compDef As AssemblyComponentDefinition) As Face For Each oFace As Face In oBody.Faces If oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then Dim oAxis As WorkAxis oAxis = compDef.WorkAxes.AddFixed(oFace.Geometry.BasePoint, oFace.Geometry.AxisVector) If oAxis.Line.IsColinearTo(oAxis1.Line) Then oAxis.Delete() Return oFace Exit Function Else oAxis.Delete() End If End If Next Return Nothing End Function Public Function EndsWith(Str As String, ending As String) As Boolean Dim endingLen As Integer endingLen = Len(ending) EndsWith = (Microsoft.VisualBasic.Right(Trim(UCase(Str)), endingLen) = UCase(ending)) End Function
AlexFielder
Does that work then? It looks like it will to my eyes.
From everything i was reading, I thought I was doing it right. but I still was getting the same error.
(is there a simple way to go from vba to vba.net)
AlexFielder
You've got one error which can be fixed like this:
Change this:
To this:
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "Hole Alignment")
yes that works perfectly Smiley Happy
