- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to retrieve the parent(s) of each occurrence in the master assembly. The rule I have is not giving the correct parent data. I request someone help. Thanks.
Public Class RWEI_0001A Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt" Sub Main() 'Accessing Assembly Components @ https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html Dim oDashes As String = "" Dim iL_NO As String = "0001A-BOM" Dim iL_Name As String = "All Occurrences with BOM Structure" Dim iL_FullName As String = "Rule " & iL_NO & ": " & iL_Name Dim oDoc As Document = ThisApplication.ActiveDocument oDelete_ex_Notepad(oTextSave, iL_NO) oHL1 = "FILE REFERENCE TREE RAN FROM: " & oDoc.FullFileName oWrite_HeaderLines(oTextSave, oHL1) oHL2 = iL_FullName oWrite_HeaderLines(oTextSave, oHL2) For i = 1 To Len(iL_FullName) oDashes = oDashes & "-" Next i oWrite_DashLine(oTextSave, oDashes) ' Get the active assembly. Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument ' Call the function that does the recursion. Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1) Process.Start("Notepad.exe", oTextSave) End Sub Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. Dim oOcc As ComponentOccurrence For Each oOcc In Occurrences ' Print the name of the current occurrence. ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences, Level + 1) End If oParent = System.IO.Path.GetFileNameWithoutExtension(oOcc.Parent.Document.DisplayName) oData_X = oParent & "@" & oOcc.Name & "@" & "Level - " & Level oWrite_Data(oTextSave, oData_X) ' MessageBox.Show(oOcc.Parent.Document.DisplayName) Next End Sub Function GetOccurrenceParent(oOcc As ComponentOccurrence, oOccName As String) Return oOcc.Parent.Document.DisplayName End Function 'Process.Start("Notepad.exe", oTextSave) Sub oWrite_Data(oTextSave As String, oData As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oData) oWrite.Flush() oWrite.Close End Sub Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oHeaderLine) oWrite.Flush() oWrite.Close End Sub Sub oWrite_DashLine(oTextSave As String, oDashes As String) oWrite = System.IO.File.AppendText(oTextSave) oWrite.WriteLine(oDashes) oWrite.Flush() oWrite.Close End Sub Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String) 'To delete oTextSave if existing. ' Dim FileDelete As String ' FileDelete = "C:\testDelete.txt" If System.IO.File.Exists(oTextSave) = True Then System.IO.File.Delete(oTextSave) MessageBox.Show("Existing (if any) File Deleted", iL_NO) End If End Sub End Class 'Function GetOccurrenceParent(oOcc As ComponentOccurrence, oOccName As String) ' For Each occ In oSubOcc.SubOccurrences ' If occ.SubOccurrences.Count <> 0 Then ' If occ.Name = PartNameToLookFor Then ' MessageBox.Show(occ.Name & " is inside " & occ.ParentOccurrence.Name, "Title") ' Else ' GetOccurrenceParent(occ, PartNameToLookFor) ' End If ' Else ' If occ.Name = PartNameToLookFor Then ' MessageBox.Show(occ.Name & " is inside " & occ.ParentOccurrence.Name, "Title") ' End If ' End If ' Next ' Return oParent 'End Function
