To find Parent of Occurrences
RoyWickrama_RWEI
RoyWickrama_RWEI
I am trying to retrieve the parent(s) of each occurrence in the master assembly. The rule I have is not giving the correct parent data. I request someone help. Thanks.
Public Class RWEI_0001A
	Shared oTextSave As String = "C:\Users\Public\Documents\iLogicBuffer.txt"
Sub Main()
	'Accessing Assembly Components @ https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
	Dim oDashes As String = ""
	Dim iL_NO As String = "0001A-BOM"
	Dim iL_Name As String = "All Occurrences with BOM Structure"
	Dim iL_FullName As String = "Rule " & iL_NO & ": " & iL_Name
	Dim oDoc As Document = ThisApplication.ActiveDocument
	oDelete_ex_Notepad(oTextSave, iL_NO)
	oHL1 = "FILE REFERENCE TREE RAN FROM: " & oDoc.FullFileName
	oWrite_HeaderLines(oTextSave, oHL1)
	oHL2 = iL_FullName
	oWrite_HeaderLines(oTextSave, oHL2)
	For i = 1 To Len(iL_FullName)
		oDashes = oDashes & "-"
	Next i
	oWrite_DashLine(oTextSave, oDashes)
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Call the function that does the recursion.
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
	Process.Start("Notepad.exe", oTextSave)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
        ' Print the name of the current occurrence.
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
        End If
	oParent = System.IO.Path.GetFileNameWithoutExtension(oOcc.Parent.Document.DisplayName)
	oData_X = oParent & "@" & oOcc.Name & "@" & "Level - " & Level
	oWrite_Data(oTextSave, oData_X)
'	MessageBox.Show(oOcc.Parent.Document.DisplayName)
	Next
End Sub
Function GetOccurrenceParent(oOcc As ComponentOccurrence, oOccName As String)
	Return oOcc.Parent.Document.DisplayName
End Function
'Process.Start("Notepad.exe", oTextSave)
Sub oWrite_Data(oTextSave As String, oData As String)
	oWrite = System.IO.File.AppendText(oTextSave)
	oWrite.WriteLine(oData)
	oWrite.Flush()
	oWrite.Close
End Sub
Sub oWrite_HeaderLines(oTextSave As String, oHeaderLine As String)
	oWrite.WriteLine(oHeaderLine)
	oWrite.Flush()
	oWrite.Close
End Sub
Sub oWrite_DashLine(oTextSave As String, oDashes As String)
	oWrite.WriteLine(oDashes)
	oWrite.Flush()
	oWrite.Close
End Sub
Sub oDelete_ex_Notepad(oTextSave As String, iL_NO As String)		'To delete oTextSave if existing.
'	Dim FileDelete As String
'	FileDelete = "C:\testDelete.txt"
 	If System.IO.File.Exists(oTextSave) = True Then
   	System.IO.File.Delete(oTextSave)
	MessageBox.Show("Existing (if any) File Deleted", iL_NO)
	End If
End Sub
End Class
'Function GetOccurrenceParent(oOcc As ComponentOccurrence, oOccName As String)
'    For Each occ In oSubOcc.SubOccurrences
'        If occ.SubOccurrences.Count <> 0  Then
'                If occ.Name = PartNameToLookFor Then
'                    MessageBox.Show(occ.Name & " is inside " & occ.ParentOccurrence.Name, "Title")
'                Else
'                    GetOccurrenceParent(occ, PartNameToLookFor)
'                End If
'        Else
'            End If
'        End If
'    Next
'	Return oParent
'End Function
Replies (8)
Sergio.D.Suárez
Hi, I tweak your code a bit, I think it's now what you're looking for. Please check it out and see if we can improve it. regards
Sub Main()
	oHL2 = iL_FullName
	Next i
End Sub
        End If
		Try
			Dim oParentocc As ComponentOccurrence
			oParentocc = oOcc.ParentOccurrence
			oParent = oParentocc.Name
		Catch
		End Try
	Next
End Sub
End Function
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
	End If
End Sub
End Class
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
RoyWickrama_RWEI
Oh. Very nice. It is working.
Thanks a lot.
Let me try with bigger assemblies. I hope, you would not mind if you revert back to you for further help.
Once again, thanks a lot.
RoyWickrama_RWEI
Based on your idea, I further explored: I found the following works well except it does not carry the file extension although it is the full file name.
'		Try
'			Dim oParentocc As ComponentOccurrence
'			oParentocc = oOcc.ParentOccurrence
'			oParent = oParentocc.Name
'		Catch
'			MessageBox.Show("@ Catch", "Title")
'			oParent = System.IO.Path.GetFileNameWithoutExtension(oOcc.Parent.Document.DisplayName)
'		End Try
			docFile = oOcc.Definition.Document
    		oParent = System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName)
Do you think can I have the file extension as well: Thanks.
JaneFan
How about changing the lines to get parent like this:
If Level >1 Then
		oParent = System.IO.Path.GetFileNameWithoutExtension(oOcc.ParentOccurrence.Name )
	Else
	End If
Jane Fan
Inventor QA Engineer
Sergio.D.Suárez
waaa !! that simple and summarized method, I can hardly prove it
Mechanical Designer
RoyWickrama_RWEI
Hi Jane Fan;
Thanks for responding to my request. It did not retrieve the parent children. See Figure - 1.
I modified as follows,
If Level > 1 Then
	oParent = System.IO.Path.GetFileNameWithoutExtension(oOcc.ParentOccurrence.Definition.Document.FullFileName)
Else
End If
and it is working. Pl. see Figure - 2
RoyWickrama_RWEI
It is a smart tweek but not quite right (see the figure below) . It led me to tweek as follows and it is fine.
Thanks again for your help.
Try
	docFile = oParentocc.Definition.Document
    oParent = System.IO.Path.GetFileName(docFile.FullFileName)
Catch
	oParent = System.IO.Path.GetFileName(oOcc.Parent.Document.DisplayName)
End Try
RoyWickrama_RWEI
Final solution is:
Sub Main()
	Dim iL_NO As String = "0009-BOM"
	oHL2 = iL_FullName
	Next i
End Sub
        End If
		oFFN_cw_EXT = oOcc.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName	'cw file extension
		oStr = oDoc_LocalName_WExt(iL_NO, oFFN_cw_EXT)
		BOM_Structure_Return = Func_BOM_Structure(iL_NO, oOcc)
			'specify word splitting characters "space" and "dash"
			Dim Separators() As Char = {"*"c}
			Sentence = BOM_Structure_Return
			Words = Sentence.Split(Separators)
			i = 0
			For Each wrd In Words
			'MessageBox.Show("Word Index #" & i & " = " & Words(i))
			i += 1
			Next
		BOM_Structure = Words(0)
		oOccurrence_FFN = Words(1)
'		oParent = oOcc.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName
		Try
		Catch
		End Try
'		If Level > 1 Then
'			oParent = System.IO.Path.GetFileNameWithoutExtension(oOcc.ParentOccurrence.Definition.Document.FullFileName)
'		Else
'		End If
		oData_X = oParent & "@" & oStr & "@" & "Level-" & Level & "@" & BOM_Structure
'		oData_X = oParent & "@" & oOcc.Name & "@" & "Level-" & Level & "@" & BOM_Structure
'		oData_X = oStr & "@" & oFFN_cw_EXT & "@" & BOM_Structure & " " & oParent & "@" & oOcc.Name & "@" & "Level-" & Level
	Next
End Sub
	Function oDoc_LocalName_WExt(iL_NO As String, oFFN_cw_EXT As String)
	oName_Sub = "oDoc_LocalName_WExt"
	oTitle = iL_NO & " @ SUB: " & oName_Sub
	oPos = Len(oFFN_cw_EXT) - InStrRev(oFFN_cw_EXT, "\", -1)
	oName_Local_cw_Ext = Right(oFFN_cw_EXT, oPos)
	Return oName_Local_cw_Ext 'Local file name complete with extension
	End Function
	Function Func_BOM_Structure(iL_NO As String, oCompOcc As ComponentOccurrence)
	oName_Sub = "BOM_Structure"
	Dim oOccurrence As ComponentOccurrence
	oFFN_X = oCompOcc.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName
	BOM_X = oCompOcc.Definition.BOMStructure
	If BOM_X = BOMStructureEnum.kDefaultBOMStructure Then BOM_Structure = "Default"
	If BOM_X = BOMStructureEnum.kNormalBOMStructure Then BOM_Structure = "Normal"
	If BOM_X = BOMStructureEnum.kReferenceBOMStructure Then BOM_Structure = "Reference"
	If BOM_X = BOMStructureEnum.kPhantomBOMStructure Then BOM_Structure = "Phantom"
	If BOM_X = BOMStructureEnum.kPurchasedBOMStructure  Then BOM_Structure = "Purchased"
	If BOM_X = BOMStructureEnum.kInseparableBOMStructure  Then BOM_Structure = "Inseparable"
	If BOM_X = BOMStructureEnum.kVariesBOMStructure Then BOM_Structure = "Varies"
	oDoc_LocalName_WExt(iL_NO, oFFN_X)
	'BOM_Structure = oDoc_LocalName_WExt(iL_NO, oFFN_X) & " <- " & BOM_Structure & "(BOM STATUS: Default)"
	Dim BOM_Structure_Return As String = BOM_Structure & "*" & oFFN_X
	Return BOM_Structure_Return
	End Function
End Function
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
	oWrite.Flush()
	oWrite.Close
End Sub
'	MessageBox.Show("Existing (if any) File Deleted", iL_NO)
	End If
End Sub
End Class
