To Edit User Parameter from within current Sketch
RoyWickrama_RWEI
RoyWickrama_RWEI
In my skeleton modeling, the master sketch is too big and contains so many user parameters. Some times, need to edit the user parameter on the fly.
Could I get some iLogic code to edit the user parameter by selecting the dimension (for example, Length_03 as shown below)?
MechMachineMan
In the DIMENSION box, as shown, type:
Length_03 = 10
where 10 is your new value.
No iLogic required.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
rhasell
Hi
I have been following this thread, as I have the same question, does this now work in the new version of Inventor?
I still only have 2018, and it does not work for "User Parameters", only "Model parameters"
Reg
2025.2
RoyWickrama_RWEI
Thanks for the reply.
I have a little code created. But it is lacking to get copied the name of the assigned-user-parameter of the dimension selected.
Please see attached sample file.
RoyWickrama_RWEI
Thanks. You are right. I need to get around this. I appreciate if you could help.
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Hoping that below iLogic code would help to edit user parameter of selected dimension.
Sub Main()
	Dim oSelectedDim As DimensionConstraint
	oSelectedDim = ThisApplication.Commandmanager.Pick(SelectionFilterEnum.kSketchDimConstraintFilter,"Select a dimension to change dimension")
    If oSelectedDim.Parameter.DrivenBy.Count > 0 Then
        Dim oUserParam As UserParameter
        oUserParam = oSelectedDim.Parameter.DrivenBy.Item(1)
        oUserParam.Expression = InputBox("Editing user parameter '" & oUserParam.Name & "'", "Edit user parameter", "10")
    Else
        MsgBox ("Selected dimension is not contianing any user parameter")
    End If
    iLogicVb.UpdateWhenDone = True
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Like".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
RoyWickrama_RWEI
It works, I keep using.
I have a little concern. After editing the user parameter, it closes the sketch being edited. Can I have the sketch remaining so that the other edits too can be done and close the sketch by myself.
Thanks.
