To build up rule commomn for Part, Assembly and Drawing Documents
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I need to run some of my rules in part, assembly and drawing documents. But I could never do it despite I spend a lot of time. It runs for drawings only and gives error shown below for other documents.
Sample rule is attached.
dgreatice
Change
ThisDrawing to ThisDoc
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
chandra.shekar.g
Autodesk Support
Autodesk Support
@RoyWickrama_RWEI,
Try below iLogic code.
Sub Main()
	oRuleNo = "RULE NO: iL0071"
	'Dim oDoc As DrawingDocument
	'oDoc = ThisApplication.ActiveDocument
	'check file type
	If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		MessageBox.Show("Drawing document!", oRuleNo)
		oProcess_Dwg()
	If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		MessageBox.Show("ASSEMBLY Document!", oRuleNo)
		oProcess_Assy()
	If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		MessageBox.Show("PART Document!", oRuleNo)
		oProcess_Part()
End Sub
Sub oProcess_Dwg()
	oModelDoc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
End Sub
Sub oProcess_Assy()
End Sub
Sub oProcess_Part()
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
RoyWickrama_RWEI
Thanks a lot. It is doing well.
I appreciate your hep.
@dgreatice wrote:
Change
lp.
