Thread tool not working
Good morning. Windows has updated and I can no longer use the thread tool in Inventor 2013. Also if I try to edit an existing thread it only has the original thread type. I tried the System "UseLibXL" fix that did not work. Is there something else that will get my thread tool working?
Vacherie18
My company has this same exact issue this week.
I was able to fix it with the instructions listed in the link listed below, but creating a threaded hole now takes almost 30 seconds before the options pop up so I'm not sure this is the proactive fix.
Something had to cause this.
http://www.inventortales.com/2014/03/cant-select-threads-in-autodesk.html
