The process cannot access the file... VB File
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We are upgrading from Inventor 2017 to Inventor 2020.
I have migrated the files and I'm now testing our existing iLogic code is still working correctly.
I'm coming across the following exception:
"The process cannot access the file 'C:\Users\cadflow\AppData\Local\Temp\iLogic Rules\DebugHelper.vb' because it is being used by another process."
DebugHelper.vb is a straight vb file - we've been using this vb file since Inventor 2013.
We utilize iLogic heavily - we have models that are written entirely in iLogic and some that the iLogic calls out to a dll that we've built in Visual Studio.
Caveat here is that we run multiple instances of Inventor that concurrently process iLogic rules - similar to how the Task Scheduler can run multiple instances.
Similar issue to this post: https://forums.autodesk.com/t5/inventor-customization/ilogic-error-when-using-task-scheduler/td-p/84...
Any help is appreciated.
It would be nice to understand what has changed between 2017>2020 in how iLogic compiles/executes code to result in this exception. I can see the path has changed to %temp$\iLogic Rules\ for starters.
Tom
