TASK SCHEDULER: MASS SELECT OUTPUT FOLDER
When using Task schedular to publish DWFs for example, you are required to select an Output Folder per file/folder. This can become a pain when managing multiple files/folders within the same task. Is there a way to mass select the files when chosing the output folder?
Replies (0)
