Switch off part visibility in sub-assembly
sheetal.b
sheetal.b
I have an assembly 'A' with a lot of sub-assemblies.
One of these is 'Subassembly B'. The quantity of 'Subassembly B' in 'Assembly A' is variable.
In 'Subassembly B', I need to switch on/off the visibility of 'Part 1' according to user input.
I have already made a form for the user input.
Part 1 required?: Yes/no
How can I switch off visibility of all occurrences of 'Part 1'?
JhoelForshav
Hi @sheetal.b
The trick to find all these occurrences is to use Occurrences.AllReferencedOccurrences in your main assembly.
All you need is a document-object for your 'Part 1'. Here's an example, assuming the subassembly occurrences are named 'Subassembly B:1', 'Subassembly B:2', 'Subassembly B:3' and so on. And the 'Part1'-occurrence in the subassembly is named 'Part1:1'.
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
Dim subAsm As AssemblyDocument = oDef.Occurrences.ItemByName("Subassembly B:1").Definition.Document
Dim part1 As PartDocument = subAsm.ComponentDefinition.Occurrences.ItemByName("Part1:1").Definition.Document
For Each oOcc As ComponentOccurrence In oDef.Occurrences.AllReferencedOccurrences(part1)
	oOcc.Visible = False
Next
TomaszDąbrowski
Try this code
Dim oDoc As AssemblyDocument =  ThisDoc.Document
Dim subAssembly As AssemblyDocument
'here declare your names - subassembly and part to hide
Dim subAssemblyName As String = "Subassembly B"
Dim subPartName As String = "Part 1"
Dim hide As Boolean = True 'this must be connected with your form
'maybe create a boolean parameter and put it in your form,
'then you can replace this "true" with your parameter value
For Each subOcc As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences
	If subOcc.Name.Contains(subAssemblyName) Then
		subAssembly = subOcc.Definition.Document
	Exit for
	End If
Next
If subAssembly Is Nothing Then Return
For Each oOcu As ComponentOccurrence In subAssembly.ComponentDefinition.Occurrences
		If oOcu.Name.Contains(subPartName) Then
			If hide=True Then
			oOcu.Visible = False
				Else
			oOcu.Visible = True
			End If
			Else
			oOcu.Visible = True
		End If
	Next
