Sweep length rule fails when creating/modifying the part within an assembly
lhintonC3ZNZ
lhintonC3ZNZ
Hi all,
I'n new to Ilogic but seeing the possibilities through it.
I have a rule (blatantly borrowed off the internet) for calculating the length of a sweep.  I've created a template with the code imbedded with it.
When I create the part from the part menu (File, new, part), the rule runs as expected, however when I create the part through within an assembly(open assembly, then "file, create in-place component"), when the rule runs it gives me an error "
It's very frustrating as the rule runs as it should otherwise, it's only when creating the part within an assembly! Any ideas?  I'd appreciate any help.  Thanks
The ilogic is below, however I'm not convinced its the code itself as it runs perfectly as a standalone part.
Sub main
         'Set a reference to the active part document
    Dim oDoc As PartDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    oDef = oDoc.ComponentDefinition
         Dim LengthTotal As Double
         LengthTotal = 0
         'add length of all sweeps
         Dim oSweep As SweepFeature
         For Each oSweep In oDef.Features.SweepFeatures
                 Dim oPath As Path
                 oPath = oSweep.path
                 LengthTotal = LengthTotal + GetLengthOfSweep(oPath)
         Next oSweep
    Dim oparams As Parameters
    Dim oparam As Parameter
    oparams = oDoc.ComponentDefinition.Parameters
    Dim exists As Boolean
    exists = False
    'Find out if parameter exists
         Dim paraName As String
         paraName = "Length"
    For Each oparam In oparams
    If oparam.Name = paraName Then exists = True
    Next oparam
    'Change the value if the parameter exists otherwise add the parameter
    If exists Then
        oparams.Item(paraName).Value = LengthTotal
    Else
        oparams.UserParameters.AddByValue(paraName, LengthTotal, 11266)
    End If
         Call ParaExport(oDef.Parameters, paraName, kZeroDecimalPlacePrecision)
    oDoc.Update
End Sub
'get length of a sweep
Private Function GetLengthOfSweep(ByVal oPath As Path) As Double
    Dim TotalLength As Double
    TotalLength = 0
    Dim oCurve As Object
    Dim i As Integer
    For i = 1 To oPath.Count
        oCurve = oPath.Item(i).Curve
        Dim oCurveEval As CurveEvaluator
        oCurveEval = oCurve.Evaluator
        Dim MinParam As Double
        Dim MaxParam As Double
        Dim length As Double
        Call oCurveEval.GetParamExtents(MinParam, MaxParam)
        Call oCurveEval.GetLengthAtParam(MinParam, MaxParam, length)
        TotalLength = TotalLength + length
    Next i
         Return TotalLength*1.2
End Function
'exporting the parameter, optional
Private Sub ParaExport(ByRef oParas As Parameters, _
                                                    ByVal oParaName As String, _
                                                    ByVal oDecimalPrecision As CustomPropertyPrecisionEnum)
    Dim oPara As Parameter
    For Each oPara In oParas
                 If String.Compare(oPara.name, oParaName) = 0 Then
            If Not oPara.ExposedAsProperty = True Then oPara.ExposedAsProperty = True
            If Not oPara.CustomPropertyFormat.ShowUnitsString = False Then _
            If Not oPara.CustomPropertyFormat.ShowLeadingZeros = True Then _
            If Not oPara.CustomPropertyFormat.ShowTrailingZeros = False Then _
            If Not oPara.CustomPropertyFormat.Precision = oDecimalPrecision Then _
                          Dim oComment As String
                          oComment = "Is determined by by iLogic-rule: 'SweepLength'"
                          If Not oPara.Comment = oComment Then oPara.Comment = oComment
            Exit Sub
        End If
    Next oPara
End Sub
WCrihfield
Hi @lhintonC3ZNZ.  For starters, change this:
...to this:
Dim oDoc As PartDocument = ThisDoc.Document
I believe what is going on in this situation is the code is targeting the main assembly, because it is the 'active' document in that situation, instead of the part you area creating.  This change will force the code to target the local document (the document that the rule is saved within.).
Wesley Crihfield
(Not an Autodesk Employee)
lhintonC3ZNZ
You're a genius!  That makes perfect sense and it worked.  I've spent the last couple of weeks on and off trying to find the issue.  I'm really grateful, thank you.
