Sweep Feature - Multiple selected lines with highlight
NachitoMax
NachitoMax
Hey
struggling a little with a sweep feature and multiple selected lines.. I am doing the following:
Select top face with the pick method
select edge face with the pick method
find the edge between the 2 faces
create a sketch on the edge and use it as the profile
create a Sketch3D and include the edge as projected
here i need to keep selecting other edge faces to find the edge and add them to the Sketch3D so that the Sweep follows along multiple joined lines. This part isnt working for me. Also, i created a Highlight set for each face selection but when i add my sketch, they become unhighlighted....
What method do i need to keep selecting and collecting the edges? Id be ok with a function to directly select the edges too as i can change that to what i need :slightly_smiling_face:
much appreciated
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (0)
