Swapping content center parts with ilogic
zchambliss
zchambliss
So my company has been using Vault and iParts to swap between our stock parts in a template assembly based on the form selection. We've now created a custom content center and would like for the ilogic code to essentially place/swap CC parts the same way it does iParts. I've seen the code for "add" and "delete" in CC code but I was just wondering if there was an easier way. Hopefully I'm making sense with my explanation.
A.Acheson
Hi @zchambliss
Using ilogic snippets is by far the easiest methods and if you use the capture snippet tool you can add the part with all the necessary family folder structure. Attach the code your using by pasting into this post and images of any error messages (more info tab) your seeing
Regards
Alan
