Message 1 of 1
SurfaceTextureSymbol insert via Copy & Paste
we are using onls a few different symbols for surface texture, so I would like to make it more comfortable for the user to insert the symbols.
My idea is the following workflow:
- via a buttton in the ribbon-menu a form with the availible symbols for surface texture opens up and stays until it's closed by the user
- when pressing a button "insert symbol" in the form the selected symbol is created as a template and it's been placed on the actual sheet in a "region of no interest"
- the template-symbol is been selected automatically and it's been copied to clipboard via CommandManager.ControlDefinition("AppCopyCmd")
- because inserting a copied symbol while anything is selected, the actual SelectionSet is been cleared.
- by using the CommandManager.ControlDefinition("AppPasteCmd") the process of inserting is being started (when using it manually the user can now choose the entity to connect the symbol to)
- finally the template is been removed from the sheet
I've tried a similar process in another way, but I like to know, if this way could be done also, because it seems to be quite simple to implement ;-). Thanks @JelteDeJong for his solution!
Add surface-finish to ExtensionLine by picking interactive from drawing
So, that's the plan .... and here is the code I've been written for that (just the process of insert dummy and try to start the copy & paste-process) ... But nothing happens at all, besides that the template is created.
Would be great if you share you thoughts an help me along with this.
Public Sub InsertSurfaceFinishByCopyAndPaste()
' check, if active document is a drawing
If Not ThisApplication.ActiveDocument.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject _
Then
MsgBox ("Funktion kann nur in einer Zeichnung verwendet werden.")
Exit Sub
' Dimensionierung und Setzen der benötigten Variablen
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oLeaderPoints As Inventor.ObjectCollection
Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
Dim oSurfaceSymbol As SurfaceTextureSymbol
Dim oSymbol As SurfaceTextureSymbol
Dim SymbolIndex As Integer
SymbolIndex = oSheet.SurfaceTextureSymbols.Count + 1
' Erzeugen eines Dummy-Symbols
oLeaderPoints.Clear
Call oLeaderPoints.Add(oTG.CreatePoint2d(0.1, 0.1))
Set oSymbol = oSheet.SurfaceTextureSymbols.Add(oLeaderPoints)
oSymbol.AllAroundSymbol = True
' select the template-symbol
Dim oSelectSet As SelectSet
Set oSelectSet = ThisApplication.ActiveDocument.SelectSet
Call oSelectSet.Clear
Call oSelectSet.Select(oSymbol)
' Execute the COPY command.
Dim oCopyControlDef As ControlDefinition
Set oCopyControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd")
Call oCopyControlDef.Execute
Call oSelectSet.Select(oSheet) ' this works in the interactive process very well
' Execute the PASTE command.
Dim oPasteControlDef As ControlDefinition
Set oPasteControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd")
Call oPasteControlDef.Execute
' delete the dummy-symbol
End Sub
