Supressing folders - slight variation - Manufacturing DevBlog
andrew_canfield
andrew_canfield
I've used this code:
https://adndevblog.typepad.com/manufacturing/2015/05/suppress-folder-in-assembly.html
Which will supress top level folders but not he lower lever ones - reading the code am i misunderstanding
' Recursive function as there could be subfolders too
Thinking these are lower sub assembly folders?
Sorry to keep going on about this - just feel the end is so close!
Regards
Andrew
JamieVJohnson2
Recursive functions call themselves, but when and how is what matters.  Example:
Function CrawlTree (tn as TreeNode) as list(of nodes)
dim listNodes as new list(of TreeNode)
'look for children items
for each subNode as TreeNode in tn.Nodes
      listnodes.add(subNode)
'check to see if children have children of their own
    if subNode.Nodes.count > 0 then
'here is the recursion, calling itself until then sub node count is 0
     listNodes.addrange(CrawlTree(subNode))
next
return listNodes
End Function
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
andrew_canfield
I've found this which will name each part within an assembly (but would like it to name each folder).
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
     oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
     oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
     oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
        xx = oOcc.Name
		MessageBox.Show(xx, "Title")
    Next
Also this which will supress  a folder (but only the top level )
oPane = ThisDoc.Document.BrowserPanes.Item("Model")
oFolder = oPane.TopNode.BrowserFolders.Item("Ref")
oFolderNodes = oFolder.BrowserNode.BrowserNodes
For Each oNode As BrowserNode In oFolderNodes
	oComp = oNode.NativeObject
	oComp.Suppress
Next
Trying to merge the two bits of code - not sure if 'TopNode' means just the top of the browser?
https://forums.autodesk.com/t5/inventor-customization/suppressing-folders-using-ilogic-not-updating-...
https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Would like to find all folders named 'Ref' within the assembly tree.
Regards
Andrew
