Supressing Assembly Patterns Elements
I have an assembly I am making 'intelligent'. I would like to pattern a sub-assembly to create different configurations. ie, double, triple, L-shape, T-shape. I have a form linked to text user parameters, which link to the pattern and elements being suppressed.
With the route I have gone down, its gets stuck because the pattern number essentially ends up the same in some cases so the suppressions then get confused I think.
Would it be better to use a 'place' command to create the configurations perhaps? Or a way of differentiating between pattern number per configuration?
See rule below:
	Dim oDoc As AssemblyDocument
		oDoc = ThisApplication.ActiveDocument
	'reference the pattern in the assembly
	Dim oPattern As OccurrencePattern
	'calls the pattern by name
	oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("SPILL SHAPE")
	If SPILL_No = "1. SINGLE" Then
		Parameter("DISTANCE1") = LENGTH+10
		Parameter("LEFT_RIGHT") = 1
		Parameter("DISTANCE2") = LENGTH+10
		Parameter("FRONT_BACK") = 1
		Try
		Finally
			oPattern.OccurrencePatternElements(1).Suppressed = False
		End Try
	End If
	If SPILL_No = "2. DOUBLE" Then
		Parameter("LEFT_RIGHT") = 2
		Try
		Finally
			oPattern.OccurrencePatternElements(2).Suppressed = False
		End Try
	End If
	If SPILL_No = "3. TRIPLE" Then
		Parameter("LEFT_RIGHT") = 3
		Try
		Finally
			oPattern.OccurrencePatternElements(3).Suppressed = False
		End Try
	End If
	If SPILL_No = "4. QUAD" Then
		Parameter("LEFT_RIGHT") = 4
		Try
		Finally
			oPattern.OccurrencePatternElements(4).Suppressed = False
		End Try
	End If
	If SPILL_No = "5. FIVE" Then
		Parameter("LEFT_RIGHT") = 5
		Try
		Finally
			oPattern.OccurrencePatternElements(5).Suppressed = False
		End Try
	End If
	If SPILL_No = "6. DOUBLE x2" Then
		Parameter("FRONT_BACK") = 2
		Try
		Finally
		End Try
	End If
	If SPILL_No = "8. TRIPLE x3" Then
		Parameter("FRONT_BACK") = 3
		Try
		Finally
			oPattern.OccurrencePatternElements(6).Suppressed = False
			oPattern.OccurrencePatternElements(7).Suppressed = False
			oPattern.OccurrencePatternElements(8).Suppressed = False
			oPattern.OccurrencePatternElements(9).Suppressed = False
		End Try
	End If
	If SPILL_No = "9. L-SHAPE (LH)" Then
		Try
		Finally
			oPattern.OccurrencePatternElements(4).Suppressed = True
			oPattern.OccurrencePatternElements(6).Suppressed = True
		End Try
	End If
	If SPILL_No = "10. L-SHAPE (RH)" Then
		Try
		Finally
			oPattern.OccurrencePatternElements(2).Suppressed = True
		End Try
	End If
	If SPILL_No = "11. T-SHAPE" Then
		Try
		Finally
		End Try
	End If
	If SPILL_No = "12. T-SHAPE (EXTENDED)" Then
		Try
		Finally
			oPattern.OccurrencePatternElements(1).Suppressed = True
			oPattern.OccurrencePatternElements(7).Suppressed = True
			oPattern.OccurrencePatternElements(8).Suppressed = True
		End Try
	End If
RuleParametersOutput
iLogicVb.DocumentUpdate
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
Stakin
Pleaese Unsuppressed the patternelements before every time to transform .
add below code
Dim oPatternElement As OccurrencePatternElement
For Each oPatternElement In oPattern
oPatternElement.Suppressed=0
Next
