Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I have an assembly I am making 'intelligent'. I would like to pattern a sub-assembly to create different configurations. ie, double, triple, L-shape, T-shape. I have a form linked to text user parameters, which link to the pattern and elements being suppressed.
With the route I have gone down, its gets stuck because the pattern number essentially ends up the same in some cases so the suppressions then get confused I think.
Would it be better to use a 'place' command to create the configurations perhaps? Or a way of differentiating between pattern number per configuration?
See rule below:
Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument 'reference the pattern in the assembly Dim oPattern As OccurrencePattern 'calls the pattern by name oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("SPILL SHAPE") '******************************************************************************** If SPILL_No = "1. SINGLE" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 1 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 1 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False End Try End If If SPILL_No = "2. DOUBLE" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 2 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 1 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = False End Try End If If SPILL_No = "3. TRIPLE" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 3 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 1 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = False oPattern.OccurrencePatternElements(3).Suppressed = False End Try End If If SPILL_No = "4. QUAD" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 4 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 1 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = False oPattern.OccurrencePatternElements(3).Suppressed = False oPattern.OccurrencePatternElements(4).Suppressed = False End Try End If If SPILL_No = "5. FIVE" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 5 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 1 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = False oPattern.OccurrencePatternElements(3).Suppressed = False oPattern.OccurrencePatternElements(4).Suppressed = False oPattern.OccurrencePatternElements(5).Suppressed = False End Try End If If SPILL_No = "6. DOUBLE x2" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 2 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 2 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = False oPattern.OccurrencePatternElements(3).Suppressed = False oPattern.OccurrencePatternElements(4).Suppressed = False End Try End If If SPILL_No = "8. TRIPLE x3" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 3 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 3 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = False oPattern.OccurrencePatternElements(3).Suppressed = False oPattern.OccurrencePatternElements(4).Suppressed = False oPattern.OccurrencePatternElements(5).Suppressed = False oPattern.OccurrencePatternElements(6).Suppressed = False oPattern.OccurrencePatternElements(7).Suppressed = False oPattern.OccurrencePatternElements(8).Suppressed = False oPattern.OccurrencePatternElements(9).Suppressed = False End Try End If If SPILL_No = "9. L-SHAPE (LH)" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 3 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 2 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = False oPattern.OccurrencePatternElements(3).Suppressed = False oPattern.OccurrencePatternElements(4).Suppressed = True oPattern.OccurrencePatternElements(5).Suppressed = False oPattern.OccurrencePatternElements(6).Suppressed = True End Try End If If SPILL_No = "10. L-SHAPE (RH)" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 3 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 2 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = True oPattern.OccurrencePatternElements(3).Suppressed = False oPattern.OccurrencePatternElements(4).Suppressed = True oPattern.OccurrencePatternElements(5).Suppressed = False oPattern.OccurrencePatternElements(6).Suppressed = False End Try End If If SPILL_No = "11. T-SHAPE" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 3 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 2 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = False oPattern.OccurrencePatternElements(2).Suppressed = True oPattern.OccurrencePatternElements(3).Suppressed = False oPattern.OccurrencePatternElements(4).Suppressed = False oPattern.OccurrencePatternElements(5).Suppressed = False oPattern.OccurrencePatternElements(6).Suppressed = True End Try End If If SPILL_No = "12. T-SHAPE (EXTENDED)" Then Parameter("DISTANCE1") = LENGTH+10 Parameter("LEFT_RIGHT") = 3 Parameter("DISTANCE2") = LENGTH+10 Parameter("FRONT_BACK") = 3 Try Finally oPattern.OccurrencePatternElements(1).Suppressed = True oPattern.OccurrencePatternElements(2).Suppressed = True oPattern.OccurrencePatternElements(3).Suppressed = False oPattern.OccurrencePatternElements(4).Suppressed = False oPattern.OccurrencePatternElements(5).Suppressed = False oPattern.OccurrencePatternElements(6).Suppressed = False oPattern.OccurrencePatternElements(7).Suppressed = True oPattern.OccurrencePatternElements(8).Suppressed = True oPattern.OccurrencePatternElements(9).Suppressed = False End Try End If '******************************************************************************** RuleParametersOutput iLogicVb.DocumentUpdate iLogicVb.UpdateWhenDone = True InventorVb.DocumentUpdate()
Pleaese Unsuppressed the patternelements before every time to transform .
add below code
Dim oPatternElement As OccurrencePatternElement
For Each oPatternElement In oPattern.OccurrencePatternElements
oPatternElement.Suppressed=0
Next
r
