Supress all components with the same name
tomislav.peran
tomislav.peran
I would like to suppress all components in my assembly which contain the name "Cube: " in itself.
I tried making a code by using other codes as an example but, even though the code does what I want, it is not a good one.
I have no idea how to stop the code iteration backwards so I just inserted Try & Catch as a quick fix.
Otherwise, I will get an error "Cube:0" can not be found.
If somebody knows how to do this properly please let me know,
Tom
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oCubeOccPrefix = "Cube:"
i = 0
'count existing cubes, if any
For Each oOcc In oDoc.ComponentDefinition.Occurrences
	If oOcc.name.contains(oCubeOccPrefix) Then
		i = i + 1
	End If
Next
i = 1
'renumber
		oOcc.Name = oCubeOccPrefix & i 'set  name
		i = i + 1
	End If
Next
Try
	i = i - 1
Component.IsActive(oCubeOccPrefix & i) = False
Next
	i = i - 1
Next
Catch
End Try
Zach.Stauffer
For something like this I think you can do everything in a single loop instead of multiple loops and trying to keep track of everything. Try this.
Dim assemblyDoc As Inventor.AssemblyDocument = ThisApplication.ActiveDocument
Dim cubeOccurrencePrefix = "Cube:"
Dim numberOfOccurrences As Integer = 0
For Each occurrence As Inventor.ComponentOccurrence In assemblyDoc.ComponentDefinition.Occurrences
	If occurrence.Name.Contains(cubeOccurrencePrefix) Then
		numberOfOccurrences += 1
		occurrence.Name = cubeOccurrencePrefix & numberOfOccurrences
		Component.IsActive(occurrence.Name) = False
	End If
Next
tomislav.peran
Hi Zach,
Your code works perfectly. This is much much better.
Thanks a lot.
Tom
