Suppress drawing views in multiple sheets
erik
erik
Hello
I have a multiple sheet drawing and i want to replace views by suppress and unsuppress them according to different model configurations e.g "1" or "2".
I used the rule below and this worked well on a single sheet drawing, but when I got more sheets this only works on the active sheet.
How to solve this on a multiple sheet drawing? I have searched the forum without any luck.
If Parameter("30627.iam.Deling") = "2" Then
	ActiveSheet.View("VIEW1").View.Suppressed = True
	ActiveSheet.View("VIEW2").View.Suppressed = True
	ActiveSheet.View("VIEW3").View.Suppressed = False
	ActiveSheet.View("VIEW4").View.Suppressed = False
Else
	ActiveSheet.View("VIEW1").View.Suppressed = False
	ActiveSheet.View("VIEW2").View.Suppressed = False
	ActiveSheet.View("VIEW3").View.Suppressed = True
	ActiveSheet.View("VIEW4").View.Suppressed = True
End If
JhoelForshav
Hi @erik
Would this work for you? :slightly_smiling_face:
Dim oDoc As DrawingDocument = ThisDoc.Document
For Each oSheet As Sheet In oDoc.Sheets
oSheet.Activate
Else
End If
Next
erik
Hi @JhoelForshav Thanks for your answer.
Unfortunately it does not work. As long as "View1" is not on the active sheet, it returns error message "No drawing named "View1" was found.
I am quite a novice in iLogic and are not so familiar with text coding. I use most boolean functions. :winking_face:
JhoelForshav
Hi @erik
By adding On Error Resume Next I think it should work then :slightly_smiling_face:
oSheet.Activate
Else
End If
Next
erik
@JhoelForshav This works great. Thank you! :slightly_smiling_face:
