Stop VBA from triggering an iLogic rule while running
I'm using a bit of VBA which silently opens and closes a document. I'm also using the save as .dxf iLogic rule, with the trigger being on closing a document. This is causing a 'save as dxf?' message box to pop up every time I run the module!
Is there a way to stop this from happening?
Another reason this may be extra tricky is that there are some rules that I trigger from within the module that I need to run- I don't know whether this will affect how easy it is to stop the dxf rule without affecting the others.
Any help will be useful thank you!
Doesn't matter anymore- I've changed the rule to not run under these conditions Smiley Happy
