Sort BOM and renumber / Sort parts list
j.wolbers-NoTech
Message 1 of 10
j.wolbers-NoTech
I would like my BOM to be sorted by Ilogic according to the first image. Then I would like the whole thing to be renumbered according to the second image.
Finally, I want to use a separate Ilogic for the 2D drawings to automatically adjust the parts list order so that it increases from 1 (see image below).
I would really appreciate if someone can help me with this. This would save us a lot of time while making the drawings. Unfortunately, I have no knowledge of Ilogic
Kinds regards,
Jeffrey
Replies (9)
Message 2 of 10
JelteDeJong
I create this rule that will work if you are in your Assembly or in your drawing. So there is 1 rule that works in both situations.
Dim doc As DrawingDocument = ThisDoc.Document
Dim partslist As PartsList
Dim aDoc As AssemblyDocument
If (doc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject) Then
    Dim dDoc As DrawingDocument = ThisDoc.Document
    partslist = dDoc.ActiveSheet.PartsLists.Item(1)
    aDoc = partslist.ReferencedDocumentDescriptor.ReferencedDocument
Else
    aDoc = doc
Dim BOM As BOM = aDoc.ComponentDefinition.BOM
BOM.StructuredViewEnabled = True
Dim oBOMView As BOMView = BOM.BOMViews("Structured")
oBOMView.Sort("BOM Structure", True, "Vendor", False)
oBOMView.Renumber(1, 1)
    partslist.Sort("POS")
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 10
j.wolbers-NoTech
Hi @JelteDeJong
Thanks for your help.
I'm going to test the code tomorrow.
I have one more question ...
Is it possible to check whether the Title Iproperty of the 3D model has been entered while saving a 2D drawing? If this field is empty I would like to get a pop-up with a warning.
Kind regards,
Jeffrey
Message 4 of 10
j.wolbers-NoTech
Hi @JelteDeJong
You can forget the above reaction.
I have tested your code in 2D drawing.
This works well!!
However, the code does not work in an assembly (see error message below)
I have one more question...
Is it possible to check whether the ''Category'' Iproperty of the 3D model (part or assembly) has been entered while saving a 2D drawing? If this field is empty I would like to get a pop-up with a warning or if possible a form to fill it in.
The reason that this should only be checked when saving a drawing is because the category does not have to be entered for parts of which we do not make a drawing. And the category is only filled in when creating drawings, so we can prevent the message from appearing every time when saving a 3D part or assembly.
Kind regards,
Jeffrey
Message 5 of 10
JelteDeJong
i found a bug in the code (in the first line). It should be fixed in the code below.
Dim doc As Document = ThisDoc.Document
Else
    aDoc = doc
  about your second question. I would have been better if you started a new topic for that. So other people can find a solution more easy. but any way this is how you could do it.
Dim sheet As Sheet = doc.ActiveSheet
Dim view As DrawingView = sheet.DrawingViews.Item(1)
Dim refDoc As Document = view.ReferencedDocumentDescriptor.ReferencedDocument
Dim category As String = iProperties.Value(refDoc.DisplayName ,"Summary", "Category")
If (String.IsNullOrWhiteSpace(category)) Then
	Dim newCategory = InputBox("What is the category", "Title here", "Default Entry")
	iProperties.Value(refDoc.DisplayName ,"Summary", "Category") = newCategory
Jelte de Jong
Message 6 of 10
j.wolbers-NoTech
Hi @JelteDeJong
Thanks a lot for your help!
Unfortunately, this code gives an error when saving a 2D drawing of a part. In this way I cannot automatically run the rule for all 2D drawings. Is there anything that can be done about this?
Error in rule: Rule3, in document: 34694.idw
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.AssemblyDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D465-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: Interface wordt niet ondersteund (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.AssemblyDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D465-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: Interface wordt niet ondersteund (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
   at ThisRule.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
The second iLogic code works perfectly. Thanks
Kinds regards,
Jeffrey
Message 7 of 10
j.wolbers-NoTech
Is there someone else who could possibly help me fix this?
I will appreciate it very much.
Kinds regards,
Jeffrey
Message 8 of 10
JelteDeJong
Sorry i missed the follow up question. does this work for you?
Else If (doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then
    aDoc = doc
Else
	Return
If (aDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject)
	Return
Jelte de Jong
Message 9 of 10
j.wolbers-NoTech
This still gives an error.
I have now solved it together with a colleague and it now works.
Maybe not in the most beautiful way but it works;)
Dim oPartsList As partslist
Dim pDoc As PartDocument
Dim typeDoc As String, typeint As String
typeint = doc.DocumentType
If typeint = "12291" Then typeDoc = "Assembly"
If typeint = "12292" Then typeDoc = "Drawing"
If typeint = "12290" Then typeDoc = "Part"
If typeDoc = "Part" Then Exit Sub
If typeDoc = "Drawing" Then
	If dDoc.ActiveSheet.PartsLists.Item(1).PartsListRows.Count = 1 Then Exit Sub
Else
    aDoc = doc
oBOMView.Sort("BOM Structure", True, "Vendor", False, "Authority", True )
Message 10 of 10
AMN3161
i am also very new to logic but i am very shocked on how helpful this community is.
No one is getting paid for offering their help but some of the heavy hitting logic people are so helpful. You will reconize their names quickly
