Software Graphics settings in Inventor Application Options
In Inventor\Application Options\Hardware there is a check box for Software graphics that enables user to toggle on or of this. I have tried to pinpoint the exact location for where this setting is stored in Registry using Procmon and filter that monitor Path HKCU\Software\Autodesk\Inventor\RegistryVersion23.0\System\Preferences. Have not been able to find the value. I also belive that settings related to graphics settings are in addition to registry setting also stored to a file. Does anyone here know more about this and the exact registry key for this setting?
Jon.Dean
Hi @Anonymous,
Application Options are no longer stored (since Inventor 2018) in the registry, they are saved to an XML file in the following location.
C:\Users\<username>\AppData\Roaming\Autodesk\Inventor 2019\UserApplicationOptions.xml
Substitute <username> with your logon name.
Cheers
Jon.
Jon Dean
LukeDavenport
Hi Trond,
Or alternatively you can just get or set this value using:
ThisApplication.HardwareOptions.UseSoftwareGraphics = True / False
Luke
