sketch Symbol - Attached to
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey
When i add a sketch Symbol manually to my drawing over a drawing view, it stays attached to the drawing view if i move it. If i do the exact the same in code by placing the Sketch Symbol to the mouse pointer and placing it in the same position, it doesnt. When i place the Sketch Symbol at a predetermined point over the drawing view, it doesnt attach either. How can i get it to attach to the drawing view so that when the view is moved, thew Sketch Symbol also moves?
Code to attach
Dim doc As DrawingDocument
Set doc = ThisApplication.ActiveDocument
Dim modelPane As BrowserPane
Set modelPane = doc.BrowserPanes.Item("DlHierarchy")
Dim recources As BrowserNode
Set recources = modelPane.TopNode.BrowserNodes.Item("Drawing Resources")
Dim symbols As BrowserNode
Set symbols = recources.BrowserNodes.Item("Sketch Symbols")
' Replace "MySketchedSymbol" with the name of the sketched symbol name that you want to place.
Dim mySketchedSymbol As BrowserNode
Set mySketchedSymbol = symbols.BrowserNodes.Item("MySketchSymbol")
mySketchedSymbol.DoSelect
Dim cd As ControlDefinition
Set cd = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingSketchSymbolInsertCtxCmd")
cd.Execute
Manual Add Sketch Symbol - moves with drawing view
Code add Sketch Symbol - doesnt move with drawing view
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
