Sketch - Project Flat Pattern using iLogic
MateriaGris
MateriaGris
Hi everyone.
I need to use "Project Flat Pattern" on a sketch using ilogic.
In this question from 2 years ago the topic is referred to, in my case I need to add points in the projection of the bending axes., but I can't find a way to do it automatically from within iLogic.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/sketch-project-flat-pattern-api/td-p...
I am attaching an example file showing what I am interested in doing.
I really appreciate if you can help me.
SevInventor
Hello MateriaGris,
found out how to project the Flat pattern edges and bend lines and bring the sketch intend to the folded model.
Got some code of a similar topic from here:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/sketch-on-flat-pattern-issue/td-p/71...
Only the orientation and position of the sketch in the folded model is wrong:
I'm sure this task can be solved as well. Pleas feel free to further develop this code
Sub Main
'[ edit these variables as needed
sSketchName = "Flat Pattern Sketch"
'  a reference to the active document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
'verify document type is sheet metal
If oPartDoc.ComponentDefinition.Type <> 150995200 Then
	MessageBox.Show("File is not a sheet metal part.", "iLogic")
	Exit Sub
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
' Check to make sure a flat pattern is open.
If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
	Try
		If oCompDef.HasFlatPattern = False Then
			oCompDef.Unfold
		Else
			oCompDef.FlatPattern.Edit
	Catch
		MessageBox.Show("Error editting the flat pattern.", "iLogic")
	End Try
'  a reference to the active flat pattern.
Dim oFlatPattern As FlatPattern
oFlatPattern = ThisApplication.ActiveEditObject
Dim oFace As Face
oFace = oFlatPattern.TopFace
Dim oSketch As PlanarSketch
'clean up existing sketch
For Each oSketch In oFlatPattern.Sketches
	If oSketch.Name = sSketchName Then
		oSketch.Delete
Next
' Create a new sketch.
' the Second argument specifies To include/Not include
' the edges of the face in the sketch.
oSketch = oFlatPattern.Sketches.Add(oFace, False)
' Change the name.
Dim oEdges As Edges
	UpEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
	For Each Upedge In UpEdges
		Dim line As SketchLine = oSketch.AddByProjectingEntity(Upedge)
	Next
	DownEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
	For Each DownEdge In DownEdges
		Dim line As SketchLine = oSketch.AddByProjectingEntity(DownEdges)
	Next
	For Each oEdge In oFlatPattern.TopFace.Edges
		Call oSketch.AddByProjectingEntity(oEdge)
	Next
oCompDef.FlatPattern.ExitEdit
Dim oFace2 As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to add flat sketch")
Dim oSketch2 As PlanarSketch
oSketch2 = oCompDef.Sketches.Add(oFace2,True)
oSketch.CopyContentsTo(oSketch2)
oPartDoc.Save
End Sub
