Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Sketch Constrain End Points with Ilogic?
3 REPLIES 3
davis.j
346 Views, 3 Replies
davis.j
Is there a way to auto constrain end points with ILogic. When I pull in Step files and redraw them the ends aren't constrained. It seems like it is only an issue with arcs to lines. (lines to line are already constrained.)
I use the auto dimension too and turn off dimensions and leave constraints on but it doesnt attached the arcs to lines.
Labels (4)
3 REPLIES 3
Michael.Navara
in reply to: davis.j
Michael.Navara
You can merge sketch points in sketch using iLogic. Here is the sample without error checking, but it is start point how to do it
'Planar sketch must be active
Dim oSketch As PlanarSketch = ThisApplication.ActiveEditObject
Dim partDef As PartComponentDefinition = oSketch.Parent
Dim selectionFilter As SelectionFilterEnum() = New SelectionFilterEnum() {SelectionFilterEnum.kSketchPointFilter }
Dim tolerance As Double = 0.1 ' 1 = 1cm
For Each oSketchPoint As SketchPoint In oSketch.SketchPoints
	Dim nearSketchPoints As ObjectsEnumerator = partDef.FindUsingPoint(oSketchPoint.Geometry3d, selectionFilter, tolerance)
	For Each nearSketchPoint As SketchPoint In nearSketchPoints
		If nearSketchPoint Is oSketchPoint Then Continue For
		If nearSketchPoint.Parent.Name <> oSketch.Name Then Continue For
		oSketchPoint.Merge(nearSketchPoint)
	Next
Next
	Next
Next
davis.j
in reply to: Michael.Navara
davis.j
@Michael.Navara  Thanks for your input. I'd like to figure out what the DWG import tool's "Constrain End points" actually does.  If I export the sketch as a DWG, delete the geometry and then import that DWG it allows me to click that checkbox and then everything is connected once the import is done. The only problem is that there is a high change of Inventor crashing. (What else is new? 😁)
Michael.Navara
Michael.Navara
In my opinion the check box has similar effect as my code mentioned above.
If the Inventor crashes during this operation, it is a question to Autodesk. I have no idea.
