Sketch a Custom Propertie on a planar face of an occurence in an assembly.
hkempeneers
hkempeneers
We try to place a sketch with a Custom Propertie on a planar face of all appearances in an assembly. Each appearance has an unique Description and in this case we want to see them in the assembly.
I have write the following iLogic code: (The error message is below)
Does anyone know what I'm doing wrong?
Replies (8)
MjDeck
You didn't include any declaration or assignment to the variable named oOccurrence. Can you post your complete rule as a text file?
Mike Deck
Software Developer
Autodesk, Inc.
chandra.shekar.g
Autodesk Support
Autodesk Support
@hkempeneers,
Below modification may be helpful in creating sketch after selection of face.
    Dim oFace As Face
    oFace = ThisApplication.CommandManager.Pick(kPartFacePlanarFilter, "Select a face")
    Dim occ As ComponentOccurrence
    occ = oFace.ContainingOccurrence
    Dim oFaceProxy As FaceProxy
    Call occ.CreateGeometryProxy(oFace, oFaceProxy)
    If oFaceProxy.SurfaceType = kPlaneSurface Then
        oSketch = oAssDef.Sketches.Add(oFaceProxy)
    End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
hkempeneers
@MjDeck
Dim comp As Object
Dim oAssDoc As Object
comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Selecteer een component")
oAssDoc = comp
If TypeOf oOccurrence Is ComponentOccurrenceProxy Then
Prop = iProperties.Value(oAssDoc.NativeObject.Name, "Project", "Description")
Else
Prop = iProperties.Value(oAssDoc.Name, "Project", "Description")
End If
Dim oAssDef As AssemblyComponentDefinition = oAssDoc.Definition
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick (SelectionFilterEnum.kAllPlanarEntities,"Selecteer een vlak")
' make sure it Is a planar face
If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
oPlanarSurface = oFace.Geometry
'add a sketch
oSketch = oAssDef.Sketches.Add(oFace)
'trying to choose an appropriate point
'assume this planar face has one edge loop only
oEdgeLoop = oFace.EdgeLoops(1)
oMinPt = oEdgeLoop.RangeBox.MinPoint
oMaxPt = oEdgeLoop.RangeBox.MaxPoint
CenterPt = oAssDef.TransientGeometry.CreatePoint((oMaxPt.X + oMinPt.X) / 2#, (oMaxPt.Y + oMinPt.Y) / 2#, (oMaxPt.Z + oMinPt.Z) / 2#)
'get one point on the face and transform to the point2d on the sketch
'oTextPt = oSketch.ModelToSketchSpace(oPlanarSurface.RootPoint)
oTextPt = oSketch.ModelToSketchSpace(CenterPt)
'add the textbox
oSketchText = oSketch.TextBoxes.AddFitted(oTextPt, "<StyleOverride FontSize='30'>" & Prop & "</StyleOverride>")
Else
MsgBox( "Selecteer een vlak, en geen ronding, aub!")
End If
hkempeneers
@chandra.shekar.g
This modification doesn't fix my problem.
The same error message continues to appear.
chandra.shekar.g
Autodesk Support
Autodesk Support
@hkempeneers,
Can you please answer below questions?
  1. iProperty value of "Description" is taken from Top assembly or Selected occurrence?
  2. Sketch is  created in Top assembly or selected occurrence?
  3. Selected occurrence is assembly document or part document?
It's very confusion in coding.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
hkempeneers
@chandra.shekar.g
Sorry for confusing you.
I still have to gain experience in programming..
1. From selected occurrence
2. Created in Top assembly
3. Selected occurrence can be both part of assy.
chandra.shekar.g
Autodesk Support
Autodesk Support
@hkempeneers,
Try below iLogic code.
Dim comp As ComponentOccurrence
    Prop = iProperties.Value(comp.NativeObject.Name, "Project", "Description")
Else
    Prop = iProperties.Value(comp.Name, "Project", "Description")
End If
Dim oAssDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim oFace As Face
		comp.CreateGeometryProxy(oFace, oFaceProxy)
		'add a sketch
		oEdgeLoop = oFaceProxy.EdgeLoops(1)
		CenterPt = ThisApplication.TransientGeometry.CreatePoint((oMaxPt.X + oMinPt.X) / 2#, (oMaxPt.Y + oMinPt.Y) / 2#, (oMaxPt.Z + oMinPt.Z) / 2#)
		'add the textbox
Else
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
hkempeneers
@chandra.shekar.g
This code works great!
Many thanks!
