Simple iLogic Rule
Simple iLogic Rule
Sorry, just learning to use iLogic...
I need a rule at the part level.
If (Parameter A) > 60in Then a Feature will be turned on, otherwise the feature will be turned off
Thanks.
Nevermind... I found how to use conditional feature suppression.
CCarreiras
Hi!!!
With iLogic:
SyntaxEditor Code Snippet
If (Parameter A) > 60 Then
Feature.IsActive("featurename")=True
Else
Feature.IsActive("featurename")=False
End If
CCarreiras
