Announcements
Show Inventor "Extrude" Dialog Box Using a VBA Macro
isocam
isocam
Can  anybody help???
Is it possible, using a VBA macro to show the "Extrude" dialog box?
I have a macro that runs whenever I press the save button. One of the things the macro does is to check the extrusion size to standard material thicknesses. This is used for parts that require laser cutting. If the extrusion thickness is not a standard thickness then I want to automatically show the "Extrusion" dialog box so that the user can simply change the extrusion size. Is it possible to do this?
Many thanks in advance!!
Darren
bradeneuropeArthur
With the commandmanager this should be possible.
Dim cmd as thisapplication.commanđmanager("command")
Cmd.execute
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
DRoam
Hi, you can do that using the CommandManager like so:
VBA:
'~~~~~Get the Part document~~~~~
Dim oDoc As Inventor.PartDocument
Set oDoc = ThisApplication.ActiveEditDocument
'~~~~~Get the Extrude feature~~~~~
Dim oFeature As Inventor.PartFeature
Set oFeature = oDoc.ComponentDefinition.Features.ExtrudeFeatures(1)
'~~~~~Select and edit extrude feature~~~~~~
oDoc.SelectSet.Clear
oDoc.SelectSet.Select oFeature
Dim oControlDef As Inventor.ControlDefinition
Set oControlDef = ThisApplication.CommandManager.ControlDefinitions("EditExtrudeCtxCmd")
oControlDef.Execute
iLogic:
Dim oDoc As Inventor.PartDocument = ThisDoc.Document
Dim oFeature As Inventor.PartFeature = oDoc.ComponentDefinition.Features.ExtrudeFeatures(1)
oDoc.SelectSet.Select(oFeature)
Dim oControlDef As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions("EditExtrudeCtxCmd")
oControlDef.Execute
Tailor as necessary to work with your existing code and get the appropriate Extrude feature.
