SheetMetalStyle.Thickness not set
basautomationservices
Hello all,
I have some code that used to run fine in older versions of inventor. Now in 2023 setting the SheetMetalStyle.Thickness property to a parameter name does not seem to work.
Anyone else had this problem?
My code below:
                // Find the 'default_mm' sheet metal style
                SheetMetalStyle style;
                try
                    style = scDef.SheetMetalStyles["Default_mm"];
                    Logger.Info($"Retrieved sheet metal style {style.Name}");
                catch (Exception ex)
                    Logger.Error($"Failed to activate sheet metal style", ex);
                    throw;
                // this code will not be reached if sheet metal style failed to activate
                style.Activate();
                scDef.UseSheetMetalStyleThickness = false;
                style.Thickness = thicknessParameterName;   // this does not work
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Michael.Navara
Try to change thickness parameter directly
//Get source values
var part = ThisDoc.Document as PartDocument;
var scDef = part.ComponentDefinition as SheetMetalComponentDefinition;
string thicknessParameterName = "MyThickness";
try
    throw;
style.Activate();
//style.Thickness = thicknessParameterName;   // this does not work
scDef.Thickness.Expression = thicknessParameterName; // Try this instead
part.Update2();
Thanks for the reply Michael, for me the Thickness property is a string, not a parameter
Michael.Navara
Look at my code carefully. You need to use variable scDef not style
Oops.. sorry. Will try this out, thank you!
It works! thanks again
