Sheet metal parts length and width after bending
Ahmed.shawkyXTZHN
Ahmed.shawkyXTZHN
Hi all , is there a code or a way to get sheet metal part length , width and height after bending  to be shown in part list same as flat pattern , thanks in advance
Accepted solutions (3)
Replies (11)
Andrii_Humeniuk
Hi @Ahmed.shawkyXTZHN . You can get the overall dimensions of the part using the OrientedMinimumRangeBox function. The results are in lines 11-13.
Dim oDoc As Document = ThisDoc.Document
If Not TypeOf oDoc Is PartDocument Then Exit Sub
Dim oPDoc As PartDocument = oDoc
Dim oBodies As SurfaceBodies = oPDoc.ComponentDefinition.SurfaceBodies
If oBodies.Count = 0 Then Exit Sub
Dim oBox As OrientedBox = oBodies(1).OrientedMinimumRangeBox
Dim lengths(3) As Double
Dim dSize As New List(Of Double)
dSize.AddRange({oBox.DirectionOne.Length, oBox.DirectionTwo.Length, oBox.DirectionThree.Length })
dSize.Sort()
lengths(0) = dSize(2) 'Max size box (cm)
lengths(1) = dSize(1) 'Mid size box (cm)
lengths(2) = dSize(0) 'Min size box (cm)
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Ahmed.shawkyXTZHN
thanks for your quick reply , where I will find the result's ?
Andrii_Humeniuk
You did not write how you want to get the result, so it is in the code in lines 11-13, in the comments of these lines of code there is a brief description of the dimensions. Describe how you want to describe the size of your part based on the information that you can get 3 sizes (mid, min, max). Maybe you want to record this information under Part Number or something like that?
Ahmed.shawkyXTZHN
yes I mean how the result will show in the table how to link it?
Andrii_Humeniuk
Parts List displays information from part properties. That is, you can add this code to the part document and set it to a trigger. Next, you need to describe in which cell you want to write information about the dimensions of the part and in what form (Max x Min x Mid). Also need information in which units do you need the dimensions (mm, cm)?
As an example, I recorded the information about the dimensions in the Part Number.
Dim oProp As Inventor.Property = oPDoc.PropertySets("Design Tracking Properties")("Part Number")
dSize.Sort()
MessageBox.Show(dSize(2) & " cm", "Max size box")
MessageBox.Show(dSize(1) & " cm", "Mid size box")
MessageBox.Show(dSize(0) & " cm", "Min size box")
oProp.Value = Round(dSize(2), 3) & "х" & Round(dSize(1), 3) & "х" & Round(dSize(0), 3)
 I hope you understand that I need more information to better help you, I can't read minds anyway(
Ahmed.shawkyXTZHN
thanks A lot, I got the Idea , is it possible to link to custom property and to be separate results not under one property for example to be under "total length", "total width", "total height" , and for units we are using mm, thanks.
Andrii_Humeniuk
This code creates and updates information in custom properties. Max - "total length", Mid - "total width", Min - "total height". Rounding: 3 decimal places.
Dim oUOfM As UnitsOfMeasure = oDoc.UnitsOfMeasure
Dim oCustom As PropertySet = oPDoc.PropertySets("Inventor User Defined Properties")
Dim oTotlL, oTotlW, oTotlH As Inventor.Property
dSize.Sort()
lengths(0) = Round(oUOfM.ConvertUnits(dSize(2), kCentimeterLengthUnits, kMillimeterLengthUnits), 3)
lengths(1) = Round(oUOfM.ConvertUnits(dSize(1), kCentimeterLengthUnits, kMillimeterLengthUnits), 3)
lengths(2) = Round(oUOfM.ConvertUnits(dSize(0), kCentimeterLengthUnits, kMillimeterLengthUnits), 3)
Try : oCustom("total length").Value = lengths(0)
Catch : oCustom.Add(lengths(0), "total length") : End Try
Try : oCustom("total width").Value = lengths(1)
Catch : oCustom.Add(lengths(1), "total width") : End Try
Try : oCustom("total height").Value = lengths(2)
Catch : oCustom.Add(lengths(2), "total height") : End Try
Ahmed.shawkyXTZHN
thanks a lot it's working great.
Ahmed.shawkyXTZHN
@Andrii_Humeniuk thanks bro , sorry for bothering you again :grinning_face_with_sweat: , is it possible to run it as external rule to assembly , I mean instead of add it to part wise can I run it from sheet metal assembly , thanks.
Andrii_Humeniuk
This rule can be run on both PartDocument and AssemblyDocument, it searches all SheetMetal and adds size properties to it. I hope this is what you wanted?
Sub main
	oUOfM = oDoc.UnitsOfMeasure
	If TypeOf oDoc Is PartDocument Then
		Call GetBoxForSheetNetal(oDoc)
	Else If TypeOf oDoc Is AssemblyDocument Then
		Dim oAsmDoc As AssemblyDocument = oDoc
		Dim oOccs As ComponentOccurrences = oAsmDoc.ComponentDefinition.Occurrences
		If oAsmDoc.AllReferencedDocuments.Count = 0 Then Exit Sub
		For Each oRefDoc As Document In oAsmDoc.AllReferencedDocuments
			If Not TypeOf oRefDoc Is PartDocument Or
				oOccs.AllReferencedOccurrences(oRefDoc).Count = 0 Then Continue For
			If CheckPartOnSheet(oRefDoc) Then Continue For
			Call GetBoxForSheetNetal(oRefDoc)
		Next
	End If
End Sub
Private Function CheckPartOnSheet(ByVal oPDoc As PartDocument) As Boolean
	If Not oPDoc.IsModifiable Or
		oPDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Return True
	Return False
End Function
Private Sub GetBoxForSheetNetal(ByVal oPDoc As PartDocument)
	If oBodies.Count = 0 Then Return
	dSize.Sort()
End Sub
Ahmed.shawkyXTZHN
Yes , thanks a lot.
