Parts List displays information from part properties. That is, you can add this code to the part document and set it to a trigger. Next, you need to describe in which cell you want to write information about the dimensions of the part and in what form (Max x Min x Mid). Also need information in which units do you need the dimensions (mm, cm)?
As an example, I recorded the information about the dimensions in the Part Number.
Dim oDoc As Document = ThisDoc.Document
If Not TypeOf oDoc Is PartDocument Then Exit Sub
Dim oPDoc As PartDocument = oDoc
Dim oProp As Inventor.Property = oPDoc.PropertySets("Design Tracking Properties")("Part Number")
Dim oBodies As SurfaceBodies = oPDoc.ComponentDefinition.SurfaceBodies
If oBodies.Count = 0 Then Exit Sub
Dim oBox As OrientedBox = oBodies(1).OrientedMinimumRangeBox
Dim lengths(3) As Double
Dim dSize As New List(Of Double)
dSize.AddRange({oBox.DirectionOne.Length, oBox.DirectionTwo.Length, oBox.DirectionThree.Length })
dSize.Sort()
MessageBox.Show(dSize(2) & " cm", "Max size box")
MessageBox.Show(dSize(1) & " cm", "Mid size box")
MessageBox.Show(dSize(0) & " cm", "Min size box")
oProp.Value = Round(dSize(2), 3) & "Ń
" & Round(dSize(1), 3) & "Ń
" & Round(dSize(0), 3)
I hope you understand that I need more information to better help you, I can't read minds anyway(
