Setting view scale in Configurator 360
ari.sillanpaa
ari.sillanpaa
I have issues setting the view scale on the drawing when configured via Configurator 360.
ActiveSheet.View("View1").Scale = Parameter("Master Assembly.iam.ViewScaleSend")
Works within Inventor (2019) and I have also added an annotation showing the imported parameter to the drawing. This works and shows the selected scale, but the view scale will not change.
I run the rule on (New Document) and (Drawing View Change)
Any advice is greatly appreciated.
chandra.shekar.g
Autodesk Support
Autodesk Support
@ari.sillanpaa.,
Please check the same question at Configurator 360 forum using below link.
https://forums.autodesk.com/t5/configurator-360/ct-p/2041
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
ari.sillanpaa
Thank you for the replay. Unfortunately I could not find a matching case on the C360 forum. Was there a specific post you where referring to?
BR.
Ari
chandra.shekar.g
Autodesk Support
Autodesk Support
@ari.sillanpaa,
Please create new post at Confiurator 360 forum similar to this post.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
