ā08-08-2018
03:20 PM
- Mute
- Permalink
- Report
I am looking to have an iLogic rule run in the background that will set the model front view to be normal to a work plane i have in the model. This is part of a parametric model and the view in the drawings will rotate when the parameters are edited. This moves my dimensions and alters the values to be unrepresented. I am still new to inventor iLogic and could really use some help. I have tried locking the view but that has not worked. Thank you in advance.
