- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello nice peaople,
I set the LOD before doing some other stuff, which works fine as long as there is no suppressed subpart in the assembly. It crashes or fails when there is a suppressed part in the assembly, but I can't figure out why.
Second time, when whyever LOD 1 is created it works.
Dim asDoc As AssemblyDocument = ThisDoc.Document aComp = asDoc.ComponentDefinition 'Position der Detailgenauigkeit erfassen Dim ActLOD As String = aComp.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name Try aComp.RepresentationsManager.LevelOfDetailRepresentations.Item("My LOD").Activate(True) Catch aComp.RepresentationsManager.LevelOfDetailRepresentations.Add("My LOD") aComp.RepresentationsManager.LevelOfDetailRepresentations.Item("My LOD").Activate(True) End Try
Falscher Parameter. (Ausnahme von HRESULT: 0x80070057 (E_INVALIDARG))
