07:47 PM
I have some code that steps through the browser sheet names and allows you to set them. I would like to be able to be able to set the Drawing No. in each sheet title box as well.
I have pasted my code below it works for setting the browser names but only sets the active sheet title block drawing no.
I have highlighted where I believe the problem to be.
Any help with this matter would be gratefully received.
SyntaxEditor Code Snippet
Dim oDrawDoc As DrawingDocument Dim tb As Inventor.TextBox Dim oBorder As Border Dim borderDef As BorderDefinition Dim oTB1'oTB1 references to Titleblocks Dim sValue As String Dim oDrwNo Dim oPromptEnt As String Dim oSheet As Sheet Dim SheetNumber As String Dim SheetNameChange As String oDrawDoc = ThisApplication.ActiveDocument oSheet = oDrawDoc.ActiveSheet oBorder = oSheet.Border borderDef = oBorder.Definition oTB1 = oSheet.TitleBlock i = 1 On Error Resume Next 'oUseSheetNo = InputRadioBox("Use 'Sheet No.' in Drawing No.", "With Sheet No.", "Without Sheet No.", True, Title := "Use Sheet NO.") For Each oSheet In ThisApplication.ActiveDocument.Sheets SheetNumber = Mid(oSheet.Name, InStr(1, oSheet.Name,":") + 1) SheetName = oSheet.Name 'MessageBox.Show( oSheet.Name) SheetNameChange = InputBox("Is this the Sheet Name You Want??", "Set Sheet Name.", SheetName,) 'SheetNameChange = InputBox("Is this the Sheet Name You Want??", "Set Sheet Name.", SheetName,XPos:=14, YPos:=7) 'MessageBox.Show(SheetNameChange, "Title") oSheet.Name = SheetNameChange 'MessageBox.Show(SheetNumber, oSheet.Name) For Each tb In oDrawDoc.ActiveSheet.TitleBlock.Definition.Sketch.TextBoxes If tb.Text = "DRAWING NO." Then sValue = oTB1.GetResultText(tb) oDrwNo = SheetNameChange 'MessageBox.Show("Property Field: " & tb.Text & vbCrLf & "Value: " & sValue & vbCrLf & "Prompted Entry: " & tb.FormattedText, "Prompted entry") 'MessageBox.Show("Param drw no " & oDrwNo, "Title") Call oDrawDoc.ActiveSheet.TitleBlock.SetPromptResultText(tb, oDrwNo) oPromptEnt = oTB1.GetResultText(tb) 'MessageBox.Show("Prompted value " & oPromptEnt, "Title") End If i=1+1 Next Next
